pwm: lpss: use c99 initializers in structures
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Use c99 initializers for structures.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@decl@
identifier i1,fld;
type T;
field list[n] fs;
struct i1 {
 fs
 T fld;
@bad@
identifier decl.i1,i2;
expression e;
initializer list[decl.n] is;
struct i1 i2 = { is,
+ .fld = e
- e
Signed-off-by: Julia Lawall
[thierry.reding: rebased and applied same fix for Braswell]
Signed-off-by: Thierry Reding
 drivers/pwm/pwm-lpss.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/pwm/pwm-lpss.c b/drivers/pwm/pwm-lpss.c
index 7a7a934..e979825 100644
--- a/drivers/pwm/pwm-lpss.c
+++ b/drivers/pwm/pwm-lpss.c
@@ -37,13 +37,13 @@ struct pwm_lpss_chip {
 /* BayTrail */
 const struct pwm_lpss_boardinfo pwm_lpss_byt_info = {
-	25000000
+	.clk_rate = 25000000
 EXPORT_SYMBOL_GPL(pwm_lpss_byt_info);
 /* Braswell */
 const struct pwm_lpss_boardinfo pwm_lpss_bsw_info = {
-	19200000
+	.clk_rate = 19200000
 EXPORT_SYMBOL_GPL(pwm_lpss_bsw_info);
