PS3: gelic: use unsigned long for irqflags
Author: Vegard Nossum <vegard.nossum@gmail.com>
The semantic patch I used was this:
expression lock;
identifier flags;
expression subclass;
- unsigned int flags;
+ unsigned long flags;
 spin_lock_irqsave(lock, flags)
 _spin_lock_irqsave(lock)
 spin_unlock_irqrestore(lock, flags)
 _spin_unlock_irqrestore(lock, flags)
 read_lock_irqsave(lock, flags)
 _read_lock_irqsave(lock)
 read_unlock_irqrestore(lock, flags)
 _read_unlock_irqrestore(lock, flags)
 write_lock_irqsave(lock, flags)
 _write_lock_irqsave(lock)
 write_unlock_irqrestore(lock, flags)
 _write_unlock_irqrestore(lock, flags)
 spin_lock_irqsave_nested(lock, flags, subclass)
 _spin_lock_irqsave_nested(lock, subclass)
 _raw_spin_lock_flags(lock, flags)
 __raw_spin_lock_flags(lock, flags)
This patch was generated using the Coccinelle framework.
Cc: Masakazu Mokuno
Cc: Julia Lawall
Cc: Alexey Dobriyan
Signed-off-by: Vegard Nossum
Signed-off-by: John W. Linville
 drivers/net/ps3_gelic_wireless.c | 12 ++++++------
 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/net/ps3_gelic_wireless.c b/drivers/net/ps3_gelic_wireless.c
index 6b2dee0..a834b52 100644
--- a/drivers/net/ps3_gelic_wireless.c
+++ b/drivers/net/ps3_gelic_wireless.c
@@ -1024,7 +1024,7 @@ static int gelic_wl_set_encode(struct net_device *netdev,
 	struct gelic_wl_info *wl = port_wl(netdev_priv(netdev));
 	struct iw_point *enc = &data->encoding;
 	__u16 flags;
-	unsigned int irqflag;
+	unsigned long irqflag;
 	int key_index, index_specified;
 	int ret = 0;
@@ -1097,7 +1097,7 @@ static int gelic_wl_get_encode(struct net_device *netdev,
 	unsigned int key_index, index_specified;
 	int ret = 0;
@@ -1215,7 +1215,7 @@ static int gelic_wl_set_encodeext(struct net_device *netdev,
 	struct iw_encode_ext *ext = (struct iw_encode_ext *)extra;
 	__u16 alg;
 	__u16 flags;
 	int key_index;
 	int ret = 0;
@@ -1303,7 +1303,7 @@ static int gelic_wl_get_encodeext(struct net_device *netdev,
 	int key_index;
 	int ret = 0;
 	int max_key_len;
@@ -1426,7 +1426,7 @@ static int gelic_wl_priv_set_psk(struct net_device *net_dev,
 	struct gelic_wl_info *wl = port_wl(netdev_priv(net_dev));
 	unsigned int len;
 	int ret = 0;
 	pr_debug("%s:<- len=%d\n", __func__, data->data.length);
@@ -1467,7 +1467,7 @@ static int gelic_wl_priv_get_psk(struct net_device *net_dev,
 	char *p;
 	unsigned int i;
 	pr_debug("%s:<-\n", __func__);
BtrLinux
Privacy Overview
