powerpc/qe: introduce missing kfree
Error handling code following a kzalloc should free the allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f1 = E
 (x->f1 == NULL || ...)
 f(...,x->f1,...)
 return \(0\|<+...x...+>\|ptr\);
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Acked-by: Timur Tabi
Signed-off-by: Kumar Gala
Signed-off-by: Benjamin Herrenschmidt
 arch/powerpc/sysdev/qe_lib/qe_ic.c | 5 ++++-
 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/arch/powerpc/sysdev/qe_lib/qe_ic.c b/arch/powerpc/sysdev/qe_lib/qe_ic.c
index 074905c..3faa42e 100644
--- a/arch/powerpc/sysdev/qe_lib/qe_ic.c
+++ b/arch/powerpc/sysdev/qe_lib/qe_ic.c
@@ -339,8 +339,10 @@ void __init qe_ic_init(struct device_node *node, unsigned int flags,
 	qe_ic->irqhost = irq_alloc_host(node, IRQ_HOST_MAP_LINEAR,
 					NR_QE_IC_INTS, &qe_ic_host_ops, 0);
-	if (qe_ic->irqhost == NULL)
+	if (qe_ic->irqhost == NULL) {
+		kfree(qe_ic);
 		return;
 	qe_ic->regs = ioremap(res.start, res.end - res.start + 1);
@@ -352,6 +354,7 @@ void __init qe_ic_init(struct device_node *node, unsigned int flags,
 	if (qe_ic->virq_low == NO_IRQ) {
 		printk(KERN_ERR "Failed to map QE_IC low IRQ\n");
+		kfree(qe_ic);
 		return;
BtrLinux
Privacy Overview
