powerpc/powermac/pfunc_core.c: Add of_node_put to avoid memory leak
Add a call to of_node_put in the error handling code following a call to
of_find_node_by_phandle.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r exists@
local idexpression x;
expression E,E1;
statement S;
*x =
(of_find_node_by_path
|of_find_node_by_name
|of_get_parent
|of_get_next_parent
|of_get_next_child
|of_find_compatible_node
|of_match_node
if (x == NULL) S
<... when != x = E
*if (...) {
... when != of_node_put(x)
when != if (...) { ... of_node_put(x); ... }
return <+...x...+>;
* return ...;
of_node_put(x);
Signed-off-by: Julia Lawall
Signed-off-by: Benjamin Herrenschmidt
arch/powerpc/platforms/powermac/pfunc_core.c | 9 ++++++---
1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/arch/powerpc/platforms/powermac/pfunc_core.c b/arch/powerpc/platforms/powermac/pfunc_core.c
index cec6359..b0c3777 100644
--- a/arch/powerpc/platforms/powermac/pfunc_core.c
+++ b/arch/powerpc/platforms/powermac/pfunc_core.c
@@ -837,8 +837,10 @@ struct pmf_function *__pmf_find_function(struct device_node *target,
return NULL;
find_it:
dev = pmf_find_device(actor);
- if (dev == NULL)
- return NULL;
+ if (dev == NULL) {
+ result = NULL;
+ goto out;
list_for_each_entry(func, &dev->functions, link) {
if (name && strcmp(name, func->name))
@@ -850,8 +852,9 @@ struct pmf_function *__pmf_find_function(struct device_node *target,
result = func;
break;
- of_node_put(actor);
pmf_put_device(dev);
+out:
+ of_node_put(actor);
return result;
return NULL;
find_it:
- if (dev == NULL)
- return NULL;
+ result = NULL;
+ goto out;
result = func;
break;
+out:
return result;
