powerpc/powermac: Add missing of_node_put
np is initialized to the result of calling a function that calls
of_node_get, so of_node_put should be called before the pointer is dropped.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression e,e1,e2;
* e = \(of_find_node_by_type\|of_find_node_by_name\)(...)
  ... when != of_node_put(e)
      when != true e == NULL
      when != e2 = e
  e = e1
Signed-off-by: Julia Lawall
Signed-off-by: Benjamin Herrenschmidt
 arch/powerpc/platforms/powermac/setup.c | 8 ++++++--
 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/platforms/powermac/setup.c b/arch/powerpc/platforms/powermac/setup.c
index 96580b1..970ea1d 100644
--- a/arch/powerpc/platforms/powermac/setup.c
+++ b/arch/powerpc/platforms/powermac/setup.c
@@ -494,11 +494,15 @@ static int __init pmac_declare_of_platform_devices(void)
 		return -1;
 	np = of_find_node_by_name(NULL, "valkyrie");
-	if (np)
+	if (np) {
 		of_platform_device_create(np, "valkyrie", NULL);
+		of_node_put(np);
 	np = of_find_node_by_name(NULL, "platinum");
-	if (np)
+	if (np) {
 		of_platform_device_create(np, "platinum", NULL);
+		of_node_put(np);
         np = of_find_node_by_type(NULL, "smu");
         if (np) {
 		of_platform_device_create(np, "smu", NULL);
BtrLinux
Privacy Overview
