powerpc/iseries: Use kstrdup
Use kstrdup when the goal of an allocation is copy a string into the
allocated region.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression from,to;
expression flag,E1,E2;
statement S;
- to = kmalloc(strlen(from) + 1,flag);
+ to = kstrdup(from, flag);
... when != \(from = E1 \| to = E1 \)
if (to==NULL || ...) S
... when != \(from = E2 \| to = E2 \)
- strcpy(to, from);
Signed-off-by: Julia Lawall
Signed-off-by: Benjamin Herrenschmidt
arch/powerpc/platforms/iseries/vio.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/powerpc/platforms/iseries/vio.c b/arch/powerpc/platforms/iseries/vio.c
index 00b6730..b6db7ce 100644
--- a/arch/powerpc/platforms/iseries/vio.c
+++ b/arch/powerpc/platforms/iseries/vio.c
@@ -87,12 +87,11 @@ static struct device_node *new_node(const char *path,
if (!np)
return NULL;
- np->full_name = kmalloc(strlen(path) + 1, GFP_KERNEL);
+ np->full_name = kstrdup(path, GFP_KERNEL);
if (!np->full_name) {
kfree(np);
return NULL;
- strcpy(np->full_name, path);
of_node_set_flag(np, OF_DYNAMIC);
kref_init(&np->kref);
np->parent = of_node_get(parent); |
if (!np)
return NULL;
kfree(np);
return NULL;
