powerpc/fsl_rio: Add kmalloc NULL tests
Check that the result of kmalloc/kzalloc is not NULL before dereferencing it.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression *x;
identifier f;
constant char *C;
x = \(kmalloc\|kcalloc\|kzalloc\)(...);
... when != x == NULL
    when != x != NULL
    when != (x || ...)
kfree(x)
f(...,C,...,x,...)
*f(...,x,...)
*x->f
Signed-off-by: Julia Lawall
Signed-off-by: Kumar Gala
Signed-off-by: Benjamin Herrenschmidt
 arch/powerpc/sysdev/fsl_rio.c | 18 ++++++++++++++----
 1 file changed, 14 insertions(+), 4 deletions(-)
diff --git a/arch/powerpc/sysdev/fsl_rio.c b/arch/powerpc/sysdev/fsl_rio.c
index cbb3bed..757a83f 100644
--- a/arch/powerpc/sysdev/fsl_rio.c
+++ b/arch/powerpc/sysdev/fsl_rio.c
@@ -1057,6 +1057,10 @@ int fsl_rio_setup(struct of_device *dev)
 			law_start, law_size);
 	ops = kmalloc(sizeof(struct rio_ops), GFP_KERNEL);
+	if (!ops) {
+		rc = -ENOMEM;
+		goto err_ops;
 	ops->lcread = fsl_local_config_read;
 	ops->lcwrite = fsl_local_config_write;
 	ops->cread = fsl_rio_config_read;
@@ -1064,6 +1068,10 @@ int fsl_rio_setup(struct of_device *dev)
 	ops->dsend = fsl_rio_doorbell_send;
 	port = kzalloc(sizeof(struct rio_mport), GFP_KERNEL);
+	if (!port) {
+		rc = -ENOMEM;
+		goto err_port;
 	port->id = 0;
 	port->index = 0;
@@ -1071,7 +1079,7 @@ int fsl_rio_setup(struct of_device *dev)
 	if (!priv) {
 		printk(KERN_ERR "Can't alloc memory for 'priv'\n");
 		rc = -ENOMEM;
-		goto err;
+		goto err_priv;
 	INIT_LIST_HEAD(&port->dbells);
@@ -1169,11 +1177,13 @@ int fsl_rio_setup(struct of_device *dev)
 	return 0;
 err:
-	if (priv)
-		iounmap(priv->regs_win);
-	kfree(ops);
+	iounmap(priv->regs_win);
 	kfree(priv);
+err_priv:
 	kfree(port);
+err_port:
+	kfree(ops);
+err_ops:
 	return rc;
