powerpc/fsl: fsl_soc: delete unneeded test before of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Of_node_put supports NULL as its argument, so the initial test is not
necessary.
Suggested by Uwe Kleine-König.
The semantic patch that fixes this problem is as follows:
(http://coccinelle.lip6.fr/)
expression e;
-if (e)
   of_node_put(e);
Signed-off-by: Julia Lawall
Acked-by: Benjamin Herrenschmidt
Signed-off-by: Michael Ellerman
 arch/powerpc/sysdev/fsl_soc.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/powerpc/sysdev/fsl_soc.c b/arch/powerpc/sysdev/fsl_soc.c
index 1e04568..99269c0 100644
--- a/arch/powerpc/sysdev/fsl_soc.c
+++ b/arch/powerpc/sysdev/fsl_soc.c
@@ -197,8 +197,7 @@ static int __init setup_rstcr(void)
 	if (!rstcr && ppc_md.restart == fsl_rstcr_restart)
 		printk(KERN_ERR "No RSTCR register, warm reboot won't work\n");
-	if (np)
-		of_node_put(np);
+	of_node_put(np);
 	return 0;
BtrLinux
Privacy Overview
