powerpc/chrp: Add missing of_node_put in pci.c
Author: Nicolas Palix <npalix@diku.dk>
of_node_put is needed before discarding a value received from
of_find_node_by_name, eg in error handling code or when the device
node is no longer used.
The semantic match that catches the bug is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression struct device_node *n;
position p1, p2;
statement S1,S2;
expression E,E1;
expression *ptr != NULL;
if (!(n@p1 = of_find_node_by_name(...))) S1
<... when != of_node_put(n)
    when != if (...) { <+... of_node_put(n) ...+> }
    when != true !n  || ...
    when != n = E
    when != E = n
if (!n || ...) S2
  return \(0\|<+...n...+>\|ptr\);
return@p2 ...;
n = E1
E1 = n
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s of_find_node_by_name %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Nicolas Palix
Signed-off-by: Julia Lawall
Acked-by: Stephen Rothwell
Signed-off-by: Paul Mackerras
 arch/powerpc/platforms/chrp/pci.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/arch/powerpc/platforms/chrp/pci.c b/arch/powerpc/platforms/chrp/pci.c
index d3cde6b..5a72ee5 100644
--- a/arch/powerpc/platforms/chrp/pci.c
+++ b/arch/powerpc/platforms/chrp/pci.c
@@ -141,6 +141,7 @@ hydra_init(void)
 		of_node_put(np);
 		return 0;
+	of_node_put(np);
 	Hydra = ioremap(r.start, r.end-r.start);
 	printk("Hydra Mac I/O at %llx\n", (unsigned long long)r.start);
 	printk("Hydra Feature_Control was %x", |
 		of_node_put(np);
 		return 0;
+	of_node_put(np);
