powerpc/cell: Prepare irq handler for irq argument removal
Author: Thomas Gleixner <tglx@linutronix.de>
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
Cc: Jiang Liu
Cc: Arnd Bergmann
Cc: linuxppc-dev@lists.ozlabs.org
 arch/powerpc/platforms/cell/interrupt.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/powerpc/platforms/cell/interrupt.c b/arch/powerpc/platforms/cell/interrupt.c
index a15f1ef..6558e7e 100644
--- a/arch/powerpc/platforms/cell/interrupt.c
+++ b/arch/powerpc/platforms/cell/interrupt.c
@@ -99,11 +99,12 @@ static void iic_ioexc_eoi(struct irq_data *d)
-static void iic_ioexc_cascade(unsigned int irq, struct irq_desc *desc)
+static void iic_ioexc_cascade(unsigned int __irq, struct irq_desc *desc)
 	struct irq_chip *chip = irq_desc_get_chip(desc);
 	struct cbe_iic_regs __iomem *node_iic =
 		(void __iomem *)irq_desc_get_handler_data(desc);
+	unsigned int irq = irq_desc_get_irq(desc);
 	unsigned int base = (irq & 0xffffff00) | IIC_IRQ_TYPE_IOEXC;
 	unsigned long bits, ack;
 	int cascade;
BtrLinux
Privacy Overview
