powerpc/85xx: Add local_irq_restore in error handling code
There is a call to local_irq_restore in the normal exit case, so it would
seem that there should be one on an error return as well.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
expression l;
expression E,E1,E2;
local_irq_save(l);
... when != local_irq_restore(l)
    when != spin_unlock_irqrestore(E,l)
    when any
    when strict
if (...) { ... when != local_irq_restore(l)
               when != spin_unlock_irqrestore(E1,l)
+   local_irq_restore(l);
    return ...;
if (...)
+   {local_irq_restore(l);
    return ...;
spin_unlock_irqrestore(E2,l);
Signed-off-by: Julia Lawall
Signed-off-by: Kumar Gala
 arch/powerpc/platforms/85xx/smp.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/arch/powerpc/platforms/85xx/smp.c b/arch/powerpc/platforms/85xx/smp.c
index d652c71..79a0df1 100644
--- a/arch/powerpc/platforms/85xx/smp.c
+++ b/arch/powerpc/platforms/85xx/smp.c
@@ -58,6 +58,7 @@ smp_85xx_kick_cpu(int nr)
 	if (cpu_rel_addr == NULL) {
 		printk(KERN_ERR "No cpu-release-addr for cpu %d\n", nr);
+		local_irq_restore(flags);
 		return;
BtrLinux
Privacy Overview
