powerpc: Use set_cpus_allowed_ptr
Use set_cpus_allowed_ptr rather than set_cpus_allowed.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression E1,E2;
- set_cpus_allowed(E1, cpumask_of_cpu(E2))
+ set_cpus_allowed_ptr(E1, cpumask_of(E2))
expression E;
identifier I;
- set_cpus_allowed(E, I)
+ set_cpus_allowed_ptr(E, &I)
Signed-off-by: Julia Lawall
Signed-off-by: Benjamin Herrenschmidt
 arch/powerpc/kernel/smp.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/kernel/smp.c b/arch/powerpc/kernel/smp.c
index c2ee144..e36f94f 100644
--- a/arch/powerpc/kernel/smp.c
+++ b/arch/powerpc/kernel/smp.c
@@ -561,12 +561,12 @@ void __init smp_cpus_done(unsigned int max_cpus)
 	 * se we pin us down to CPU 0 for a short while
 	old_mask = current->cpus_allowed;
-	set_cpus_allowed(current, cpumask_of_cpu(boot_cpuid));
+	set_cpus_allowed_ptr(current, cpumask_of(boot_cpuid));
 	if (smp_ops && smp_ops->setup_cpu)
 		smp_ops->setup_cpu(boot_cpuid);
-	set_cpus_allowed(current, old_mask);
+	set_cpus_allowed_ptr(current, &old_mask);
 	snapshot_timebases();
BtrLinux
Privacy Overview
