powerpc: Use proper accessors for IRQ_* flags
Author: Thomas Gleixner <tglx@linutronix.de>
Use the proper accessors instead of open access to irq_desc.
Converted with coccinelle.
Signed-off-by: Thomas Gleixner
 arch/powerpc/kernel/irq.c                        | 2 +-
 arch/powerpc/kernel/machine_kexec.c              | 4 ++--
 arch/powerpc/platforms/512x/mpc5121_ads_cpld.c   | 2 +-
 arch/powerpc/platforms/52xx/media5200.c          | 2 +-
 arch/powerpc/platforms/82xx/pq2ads-pci-pic.c     | 2 +-
 arch/powerpc/platforms/85xx/socrates_fpga_pic.c  | 2 +-
 arch/powerpc/platforms/86xx/gef_pic.c            | 2 +-
 arch/powerpc/platforms/cell/beat_interrupt.c     | 3 +--
 arch/powerpc/platforms/embedded6xx/flipper-pic.c | 2 +-
 arch/powerpc/platforms/embedded6xx/hlwd-pic.c    | 4 ++--
 arch/powerpc/platforms/powermac/pic.c            | 3 +--
 arch/powerpc/platforms/pseries/xics.c            | 2 +-
 arch/powerpc/sysdev/cpm1.c                       | 2 +-
 arch/powerpc/sysdev/cpm2_pic.c                   | 2 +-
 arch/powerpc/sysdev/fsl_msi.c                    | 2 +-
 arch/powerpc/sysdev/i8259.c                      | 4 ++--
 arch/powerpc/sysdev/mv64x60_pic.c                | 2 +-
 arch/powerpc/sysdev/qe_lib/qe_ic.c               | 2 +-
 arch/powerpc/sysdev/tsi108_pci.c                 | 2 +-
 arch/powerpc/sysdev/uic.c                        | 4 ++--
 20 files changed, 24 insertions(+), 26 deletions(-)
diff --git a/arch/powerpc/kernel/irq.c b/arch/powerpc/kernel/irq.c
index 0a557033..8f7da44 100644
--- a/arch/powerpc/kernel/irq.c
+++ b/arch/powerpc/kernel/irq.c
@@ -618,7 +618,7 @@ struct irq_host *irq_alloc_host(struct device_node *of_node,
 			smp_wmb();
 			/* Clear norequest flags */
-			irq_to_desc(i)->status &= ~IRQ_NOREQUEST;
+			irq_clear_status_flags(i, IRQ_NOREQUEST);
 			/* Legacy flags are left to default at this point,
 			 * one can then use irq_create_mapping() to
diff --git a/arch/powerpc/kernel/machine_kexec.c b/arch/powerpc/kernel/machine_kexec.c
index bd1e1ff..2d65e9e 100644
--- a/arch/powerpc/kernel/machine_kexec.c
+++ b/arch/powerpc/kernel/machine_kexec.c
@@ -35,13 +35,13 @@ void machine_kexec_mask_interrupts(void) {
 		if (!chip)
 			continue;
-		if (chip->irq_eoi && desc->status & IRQ_INPROGRESS)
+		if (chip->irq_eoi && irqd_irq_inprogress(&desc->irq_data))
 			chip->irq_eoi(&desc->irq_data);
 		if (chip->irq_mask)
 			chip->irq_mask(&desc->irq_data);
-		if (chip->irq_disable && !(desc->status & IRQ_DISABLED))
+		if (chip->irq_disable && !irqd_irq_disabled(&desc->irq_data))
 			chip->irq_disable(&desc->irq_data);
diff --git a/arch/powerpc/platforms/512x/mpc5121_ads_cpld.c b/arch/powerpc/platforms/512x/mpc5121_ads_cpld.c
index fde0ea5..529897c 100644
--- a/arch/powerpc/platforms/512x/mpc5121_ads_cpld.c
+++ b/arch/powerpc/platforms/512x/mpc5121_ads_cpld.c
@@ -132,7 +132,7 @@ static int
 cpld_pic_host_map(struct irq_host *h, unsigned int virq,
 			     irq_hw_number_t hw)
-	irq_to_desc(virq)->status |= IRQ_LEVEL;
+	irq_set_status_flags(virq, IRQ_LEVEL);
 	set_irq_chip_and_handler(virq, &cpld_pic, handle_level_irq);
 	return 0;
diff --git a/arch/powerpc/platforms/52xx/media5200.c b/arch/powerpc/platforms/52xx/media5200.c
index 2bd1e6c..6cd041b 100644
--- a/arch/powerpc/platforms/52xx/media5200.c
+++ b/arch/powerpc/platforms/52xx/media5200.c
@@ -107,7 +107,7 @@ void media5200_irq_cascade(unsigned int virq, struct irq_desc *desc)
 	/* Processing done; can reenable the cascade now */
 	raw_spin_lock(&desc->lock);
 	chip->irq_ack(&desc->irq_data);
-	if (!(desc->status & IRQ_DISABLED))
+	if (!irqd_irq_disabled(&desc->irq_data))
 		chip->irq_unmask(&desc->irq_data);
 	raw_spin_unlock(&desc->lock);
diff --git a/arch/powerpc/platforms/82xx/pq2ads-pci-pic.c b/arch/powerpc/platforms/82xx/pq2ads-pci-pic.c
index 926dfda..45afeb0 100644
--- a/arch/powerpc/platforms/82xx/pq2ads-pci-pic.c
+++ b/arch/powerpc/platforms/82xx/pq2ads-pci-pic.c
@@ -106,7 +106,7 @@ static void pq2ads_pci_irq_demux(unsigned int irq, struct irq_desc *desc)
 static int pci_pic_host_map(struct irq_host *h, unsigned int virq,
 			    irq_hw_number_t hw)
 	set_irq_chip_data(virq, h->host_data);
 	set_irq_chip_and_handler(virq, &pq2ads_pci_ic, handle_level_irq);
 	return 0;
diff --git a/arch/powerpc/platforms/85xx/socrates_fpga_pic.c b/arch/powerpc/platforms/85xx/socrates_fpga_pic.c
index 79d85ac..ecb0495 100644
--- a/arch/powerpc/platforms/85xx/socrates_fpga_pic.c
+++ b/arch/powerpc/platforms/85xx/socrates_fpga_pic.c
@@ -245,7 +245,7 @@ static int socrates_fpga_pic_host_map(struct irq_host *h, unsigned int virq,
 		irq_hw_number_t hwirq)
 	/* All interrupts are LEVEL sensitive */
 	set_irq_chip_and_handler(virq, &socrates_fpga_pic_chip,
 			handle_fasteoi_irq);
diff --git a/arch/powerpc/platforms/86xx/gef_pic.c b/arch/powerpc/platforms/86xx/gef_pic.c
index 0adfe3b..9a85ac1 100644
--- a/arch/powerpc/platforms/86xx/gef_pic.c
+++ b/arch/powerpc/platforms/86xx/gef_pic.c
@@ -163,7 +163,7 @@ static int gef_pic_host_map(struct irq_host *h, unsigned int virq,
 	set_irq_chip_and_handler(virq, &gef_pic_chip, handle_level_irq);
 	return 0;
diff --git a/arch/powerpc/platforms/cell/beat_interrupt.c b/arch/powerpc/platforms/cell/beat_interrupt.c
index 0b8f7d7..0280042 100644
--- a/arch/powerpc/platforms/cell/beat_interrupt.c
+++ b/arch/powerpc/platforms/cell/beat_interrupt.c
@@ -136,14 +136,13 @@ static void beatic_pic_host_unmap(struct irq_host *h, unsigned int virq)
 static int beatic_pic_host_map(struct irq_host *h, unsigned int virq,
 			       irq_hw_number_t hw)
-	struct irq_desc *desc = irq_to_desc(virq);
 	int64_t	err;
 	err = beat_construct_and_connect_irq_plug(virq, hw);
 	if (err < 0)
 		return -EIO;
-	desc->status |= IRQ_LEVEL;
 	set_irq_chip_and_handler(virq, &beatic_pic, handle_fasteoi_irq);
 	return 0;
diff --git a/arch/powerpc/platforms/embedded6xx/flipper-pic.c b/arch/powerpc/platforms/embedded6xx/flipper-pic.c
index 0aca0e2..9d6c3ab 100644
--- a/arch/powerpc/platforms/embedded6xx/flipper-pic.c
+++ b/arch/powerpc/platforms/embedded6xx/flipper-pic.c
@@ -102,7 +102,7 @@ static int flipper_pic_map(struct irq_host *h, unsigned int virq,
 	set_irq_chip_and_handler(virq, &flipper_pic, handle_level_irq);
 	return 0;
diff --git a/arch/powerpc/platforms/embedded6xx/hlwd-pic.c b/arch/powerpc/platforms/embedded6xx/hlwd-pic.c
index 35e448b..e6e6208 100644
--- a/arch/powerpc/platforms/embedded6xx/hlwd-pic.c
+++ b/arch/powerpc/platforms/embedded6xx/hlwd-pic.c
@@ -95,7 +95,7 @@ static int hlwd_pic_map(struct irq_host *h, unsigned int virq,
 	set_irq_chip_and_handler(virq, &hlwd_pic, handle_level_irq);
 	return 0;
@@ -145,7 +145,7 @@ static void hlwd_pic_irq_cascade(unsigned int cascade_virq,
 	chip->irq_ack(&desc->irq_data); /* IRQ_LEVEL */
-	if (!(desc->status & IRQ_DISABLED) && chip->irq_unmask)
+	if (!irqd_irq_disabled(&desc->irq_data) && chip->irq_unmask)
diff --git a/arch/powerpc/platforms/powermac/pic.c b/arch/powerpc/platforms/powermac/pic.c
index c55812b..22f45d7 100644
--- a/arch/powerpc/platforms/powermac/pic.c
+++ b/arch/powerpc/platforms/powermac/pic.c
@@ -289,7 +289,6 @@ static int pmac_pic_host_match(struct irq_host *h, struct device_node *node)
 static int pmac_pic_host_map(struct irq_host *h, unsigned int virq,
 			     irq_hw_number_t hw)
 	int level;
 	if (hw >= max_irqs)
@@ -300,7 +299,7 @@ static int pmac_pic_host_map(struct irq_host *h, unsigned int virq,
 	level = !!(level_mask[hw >> 5] & (1UL << (hw & 0x1f)));
 	if (level)
 	set_irq_chip_and_handler(virq, &pmac_pic, level ?
 				 handle_level_irq : handle_edge_irq);
 	return 0;
diff --git a/arch/powerpc/platforms/pseries/xics.c b/arch/powerpc/platforms/pseries/xics.c
index 01fea46..f4bf8a9 100644
--- a/arch/powerpc/platforms/pseries/xics.c
+++ b/arch/powerpc/platforms/pseries/xics.c
@@ -470,7 +470,7 @@ static int xics_host_map(struct irq_host *h, unsigned int virq,
 	/* Insert the interrupt mapping into the radix tree for fast lookup */
 	irq_radix_revmap_insert(xics_host, virq, hw);
 	set_irq_chip_and_handler(virq, xics_irq_chip, handle_fasteoi_irq);
 	return 0;
diff --git a/arch/powerpc/sysdev/cpm1.c b/arch/powerpc/sysdev/cpm1.c
index 0476bcc..6ee2af2 100644
--- a/arch/powerpc/sysdev/cpm1.c
+++ b/arch/powerpc/sysdev/cpm1.c
@@ -103,7 +103,7 @@ static int cpm_pic_host_map(struct irq_host *h, unsigned int virq,
 	pr_debug("cpm_pic_host_map(%d, 0x%lx)\n", virq, hw);
 	set_irq_chip_and_handler(virq, &cpm_pic, handle_fasteoi_irq);
 	return 0;
diff --git a/arch/powerpc/sysdev/cpm2_pic.c b/arch/powerpc/sysdev/cpm2_pic.c
index 4730325..8ffe164 100644
--- a/arch/powerpc/sysdev/cpm2_pic.c
+++ b/arch/powerpc/sysdev/cpm2_pic.c
@@ -226,7 +226,7 @@ static int cpm2_pic_host_map(struct irq_host *h, unsigned int virq,
 	pr_debug("cpm2_pic_host_map(%d, 0x%lx)\n", virq, hw);
 	set_irq_chip_and_handler(virq, &cpm2_pic, handle_level_irq);
 	return 0;
diff --git a/arch/powerpc/sysdev/fsl_msi.c b/arch/powerpc/sysdev/fsl_msi.c
index 58e09b2..71965c6 100644
--- a/arch/powerpc/sysdev/fsl_msi.c
+++ b/arch/powerpc/sysdev/fsl_msi.c
@@ -64,7 +64,7 @@ static int fsl_msi_host_map(struct irq_host *h, unsigned int virq,
 	struct fsl_msi *msi_data = h->host_data;
 	struct irq_chip *chip = &fsl_msi_chip;
-	irq_to_desc(virq)->status |= IRQ_TYPE_EDGE_FALLING;
+	irq_set_status_flags(virq, IRQ_TYPE_EDGE_FALLING);
 	set_irq_chip_data(virq, msi_data);
 	set_irq_chip_and_handler(virq, chip, handle_edge_irq);
diff --git a/arch/powerpc/sysdev/i8259.c b/arch/powerpc/sysdev/i8259.c
index aeda4c8..8012adc 100644
--- a/arch/powerpc/sysdev/i8259.c
+++ b/arch/powerpc/sysdev/i8259.c
@@ -175,12 +175,12 @@ static int i8259_host_map(struct irq_host *h, unsigned int virq,
 	/* We block the internal cascade */
 	if (hw == 2)
-		irq_to_desc(virq)->status |= IRQ_NOREQUEST;
+		irq_set_status_flags(virq, IRQ_NOREQUEST);
 	/* We use the level handler only for now, we might want to
 	 * be more cautious here but that works for now
 	set_irq_chip_and_handler(virq, &i8259_pic, handle_level_irq);
 	return 0;
diff --git a/arch/powerpc/sysdev/mv64x60_pic.c b/arch/powerpc/sysdev/mv64x60_pic.c
index bc61ebb..c43e9bc 100644
--- a/arch/powerpc/sysdev/mv64x60_pic.c
+++ b/arch/powerpc/sysdev/mv64x60_pic.c
@@ -213,7 +213,7 @@ static int mv64x60_host_map(struct irq_host *h, unsigned int virq,
 	int level1;
 	level1 = (hwirq & MV64x60_LEVEL1_MASK) >> MV64x60_LEVEL1_OFFSET;
 	BUG_ON(level1 > MV64x60_LEVEL1_GPP);
diff --git a/arch/powerpc/sysdev/qe_lib/qe_ic.c b/arch/powerpc/sysdev/qe_lib/qe_ic.c
index 8c9ded8..6349a72 100644
--- a/arch/powerpc/sysdev/qe_lib/qe_ic.c
+++ b/arch/powerpc/sysdev/qe_lib/qe_ic.c
@@ -268,7 +268,7 @@ static int qe_ic_host_map(struct irq_host *h, unsigned int virq,
 	chip = &qe_ic->hc_irq;
 	set_irq_chip_data(virq, qe_ic);
 	set_irq_chip_and_handler(virq, chip, handle_level_irq);
diff --git a/arch/powerpc/sysdev/tsi108_pci.c b/arch/powerpc/sysdev/tsi108_pci.c
index 02c91db..088413a 100644
--- a/arch/powerpc/sysdev/tsi108_pci.c
+++ b/arch/powerpc/sysdev/tsi108_pci.c
@@ -391,7 +391,7 @@ static int pci_irq_host_map(struct irq_host *h, unsigned int virq,
 	DBG("%s(%d, 0x%lx)\n", __func__, virq, hw);
 	if ((virq >= 1) && (virq <= 4)){
 		irq = virq + IRQ_PCI_INTAD_BASE - 1;
-		irq_to_desc(irq)->status |= IRQ_LEVEL;
+		irq_set_status_flags(irq, IRQ_LEVEL);
 		set_irq_chip(irq, &tsi108_pci_irq);
 	return 0;
diff --git a/arch/powerpc/sysdev/uic.c b/arch/powerpc/sysdev/uic.c
index 835f795..a68469e 100644
--- a/arch/powerpc/sysdev/uic.c
+++ b/arch/powerpc/sysdev/uic.c
@@ -244,9 +244,9 @@ void uic_irq_cascade(unsigned int virq, struct irq_desc *desc)
 uic_irq_ret:
-	if (desc->status & IRQ_LEVEL)
+	if (irqd_is_level_type(&desc->irq_data))
+	if (!(irq_is_disabled(&desc->irq_data) && chip->irq_unmask)
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
