powerpc: Introduce the use of the managed version of kzalloc
Author: Himangi Saraogi <himangi774@gmail.com>
This patch moves data allocated using kzalloc to managed data allocated
using devm_kzalloc and cleans now unnecessary kfree in probe function.
The following Coccinelle semantic patch was used for making the change:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
  .probe = probefn,
  .remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e, e1, e2;
probefn(struct platform_device *pdev, ...) {
- e = kzalloc(e1, e2)
+ e = devm_kzalloc(&pdev->dev, e1, e2)
?-kfree(e);
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: Anatolij Gustschin
 arch/powerpc/platforms/52xx/mpc52xx_gpt.c | 6 ++----
 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/arch/powerpc/platforms/52xx/mpc52xx_gpt.c b/arch/powerpc/platforms/52xx/mpc52xx_gpt.c
index 78ac19a..3048e34 100644
--- a/arch/powerpc/platforms/52xx/mpc52xx_gpt.c
+++ b/arch/powerpc/platforms/52xx/mpc52xx_gpt.c
@@ -724,7 +724,7 @@ static int mpc52xx_gpt_probe(struct platform_device *ofdev)
 	struct mpc52xx_gpt_priv *gpt;
-	gpt = kzalloc(sizeof *gpt, GFP_KERNEL);
+	gpt = devm_kzalloc(&ofdev->dev, sizeof *gpt, GFP_KERNEL);
 	if (!gpt)
 		return -ENOMEM;
@@ -732,10 +732,8 @@ static int mpc52xx_gpt_probe(struct platform_device *ofdev)
 	gpt->dev = &ofdev->dev;
 	gpt->ipb_freq = mpc5xxx_get_bus_frequency(ofdev->dev.of_node);
 	gpt->regs = of_iomap(ofdev->dev.of_node, 0);
-	if (!gpt->regs) {
-		kfree(gpt);
+	if (!gpt->regs)
 		return -ENOMEM;
 	dev_set_drvdata(&ofdev->dev, gpt);
BtrLinux
Privacy Overview
