powerpc: Eliminate NULL test and memset after alloc_bootmem
As noted by Akinobu Mita in commit b1fceac2 ("x86: remove unnecessary
memset and NULL check after alloc_bootmem()"), alloc_bootmem and
related functions never return NULL and always return a zeroed region
of memory.  Thus a NULL test or memset after calls to these functions
is unnecessary.
This was fixed using the following semantic patch.
(http://www.emn.fr/x-info/coccinelle/)
expression E;
statement S;
E = \(alloc_bootmem\|alloc_bootmem_low\|alloc_bootmem_pages\|alloc_bootmem_low_pages\|alloc_bootmem_node\|alloc_bootmem_low_pages_node\|alloc_bootmem_pages_node\)(...)
... when != E
- BUG_ON (E == NULL);
- if (E == NULL) S
expression E,E1;
... when != E
- memset(E,0,E1);
Signed-off-by: Julia Lawall
Signed-off-by: Paul Mackerras
 arch/powerpc/kernel/setup_64.c | 2 --
 1 file changed, 2 deletions(-)
diff --git a/arch/powerpc/kernel/setup_64.c b/arch/powerpc/kernel/setup_64.c
index 169d74c..93c875a 100644
--- a/arch/powerpc/kernel/setup_64.c
+++ b/arch/powerpc/kernel/setup_64.c
@@ -606,8 +606,6 @@ void __init setup_per_cpu_areas(void)
 	for_each_possible_cpu(i) {
 		ptr = alloc_bootmem_pages_node(NODE_DATA(cpu_to_node(i)), size);
-		if (!ptr)
-			panic("Cannot allocate cpu data for CPU %d\n", i);
 		paca[i].data_offset = ptr - __per_cpu_start;
 		memcpy(ptr, __per_cpu_start, __per_cpu_end - __per_cpu_start);
BtrLinux
Privacy Overview
