[POWERPC] cell/cbe_regs.c: Add missing of_node_put
There should be an of_node_put when breaking out of a loop that iterates
using for_each_node_by_type.
This was detected and fixed using the following semantic patch.
(http://www.emn.fr/x-info/coccinelle/)
identifier d;
type T;
expression e;
iterator for_each_node_by_type;
T *d;
for_each_node_by_type(d,...)
  {... when != of_node_put(d)
       when != e = d
   return d;
+  of_node_put(d);
?  return ...;
Signed-off-by: Julia Lawall
Cc: Christian Krafft
Cc: Benjamin Herrenschmidt
Cc: David Erb
Signed-off-by: Andrew Morton
Signed-off-by: Paul Mackerras
 arch/powerpc/platforms/cell/cbe_regs.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/arch/powerpc/platforms/cell/cbe_regs.c b/arch/powerpc/platforms/cell/cbe_regs.c
index a839c6c..dbc338f 100644
--- a/arch/powerpc/platforms/cell/cbe_regs.c
+++ b/arch/powerpc/platforms/cell/cbe_regs.c
@@ -256,6 +256,7 @@ void __init cbe_regs_init(void)
 			printk(KERN_ERR "cbe_regs: More BE chips than supported"
 			       "!\n");
 			cbe_regs_map_count--;
+			of_node_put(cpu);
 			return;
 		map->cpu_node = cpu;
BtrLinux
Privacy Overview
