powerpc: ARRAY_SIZE changes in pasemi and powermac code
Author: Stoyan Gaydarov <sgayda2@uiuc.edu>
These changes were a direct result of using a semantic patch
More information can be found at http://www.emn.fr/x-info/coccinelle/
Signed-off-by: Stoyan Gaydarov
Signed-off-by: Benjamin Herrenschmidt
 arch/powerpc/platforms/pasemi/idle.c      | 2 +-
 arch/powerpc/platforms/powermac/feature.c | 4 ++--
 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/powerpc/platforms/pasemi/idle.c b/arch/powerpc/platforms/pasemi/idle.c
index 43911d8..75b296b 100644
--- a/arch/powerpc/platforms/pasemi/idle.c
+++ b/arch/powerpc/platforms/pasemi/idle.c
@@ -90,7 +90,7 @@ machine_late_initcall(pasemi, pasemi_idle_init);
 static int __init idle_param(char *p)
 	int i;
-	for (i = 0; i < sizeof(modes)/sizeof(struct sleep_mode); i++) {
+	for (i = 0; i < ARRAY_SIZE(modes); i++) {
 		if (!strcmp(modes[i].name, p)) {
 			current_mode = i;
 			break;
diff --git a/arch/powerpc/platforms/powermac/feature.c b/arch/powerpc/platforms/powermac/feature.c
index e6c0040..095de32 100644
--- a/arch/powerpc/platforms/powermac/feature.c
+++ b/arch/powerpc/platforms/powermac/feature.c
@@ -2419,13 +2419,13 @@ static int __init probe_motherboard(void)
 	dt = of_find_node_by_name(NULL, "device-tree");
 	if (dt != NULL)
 		model = of_get_property(dt, "model", NULL);
-	for(i=0; model && i<(sizeof(pmac_mb_defs)/sizeof(struct pmac_mb_def)); i++) {
+	for(i=0; model && i<ARRAY_SIZE(pmac_mb_defs); i++) {
 	    if (strcmp(model, pmac_mb_defs[i].model_string) == 0) {
 		pmac_mb = pmac_mb_defs[i];
 		goto found;
-	for(i=0; i<(sizeof(pmac_mb_defs)/sizeof(struct pmac_mb_def)); i++) {
+	for(i=0; i<ARRAY_SIZE(pmac_mb_defs); i++) {
 	    if (machine_is_compatible(pmac_mb_defs[i].model_string)) {
 		goto found;
BtrLinux
Privacy Overview
