[POWERPC] Add missing of_node_put in pseries/nvram.c
of_node_put is needed before discarding a value received from
of_find_node_by_type, eg in error handling code.
The semantic patch that makes the change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
struct device_node *n;
struct device_node *n1;
struct device_node *n2;
statement S;
identifier f1,f2;
expression E1,E2;
constant C;
n = of_find_node_by_type(...)
if (!n) S
... when != of_node_put(n)
    when != n1 = f1(n,...)
    when != E1 = n
    when any
    when strict
+ of_node_put(n);
  return -C;
  of_node_put(n);
  n2 = f2(n,...)
  E2 = n
  return ...;
Signed-off-by: Julia Lawall
Acked-by: Stephen Rothwell
Signed-off-by: Paul Mackerras
 arch/powerpc/platforms/pseries/nvram.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/powerpc/platforms/pseries/nvram.c b/arch/powerpc/platforms/pseries/nvram.c
index f68903e..42f7e38 100644
--- a/arch/powerpc/platforms/pseries/nvram.c
+++ b/arch/powerpc/platforms/pseries/nvram.c
@@ -131,8 +131,10 @@ int __init pSeries_nvram_init(void)
 		return -ENODEV;
 	nbytes_p = of_get_property(nvram, "#bytes", &proplen);
-	if (nbytes_p == NULL || proplen != sizeof(unsigned int))
+	if (nbytes_p == NULL || proplen != sizeof(unsigned int)) {
+		of_node_put(nvram);
 		return -EIO;
 	nvram_size = *nbytes_p;
BtrLinux
Privacy Overview
