[POWERPC] Add missing of_node_put in drivers/macintosh/therm_adt746x.c
of_node_put is needed before discarding a value received from
of_find_node_by_name, eg in error handling code.
The semantic patch that makes the change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
struct device_node *n;
struct device_node *n1;
statement S;
identifier f;
expression E;
constant C;
n = of_find_node_by_name(...)
if (!n) S
... when != of_node_put(n)
    when != n1 = f(n,...)
    when != E = n
    when any
    when strict
+ of_node_put(n);
  return -C;
  of_node_put(n);
  n1 = f(n,...)
  E = n
  return ...;
Signed-off-by: Julia Lawall
Acked-by: Stephen Rothwell
Signed-off-by: Paul Mackerras
 drivers/macintosh/therm_adt746x.c | 13 ++++++++++---
 1 file changed, 10 insertions(+), 3 deletions(-)
diff --git a/drivers/macintosh/therm_adt746x.c b/drivers/macintosh/therm_adt746x.c
index 54f4942..5366dc93 100644
--- a/drivers/macintosh/therm_adt746x.c
+++ b/drivers/macintosh/therm_adt746x.c
@@ -562,18 +562,24 @@ thermostat_init(void)
 		therm_type = ADT7460;
 	else if (of_device_is_compatible(np, "adt7467"))
 		therm_type = ADT7467;
-	else
+	else {
+		of_node_put(np);
 		return -ENODEV;
 	prop = of_get_property(np, "hwsensor-params-version", NULL);
 	printk(KERN_INFO "adt746x: version %d (%ssupported)\n", *prop,
 			 (*prop == 1)?"":"un");
-	if (*prop != 1)
+	if (*prop != 1) {
+		of_node_put(np);
 		return -ENODEV;
 	prop = of_get_property(np, "reg", NULL);
-	if (!prop)
+	if (!prop) {
+		of_node_put(np);
 		return -ENODEV;
 	/* look for bus either by path or using "reg" */
 	if (strstr(np->full_name, "/i2c-bus@") != NULL) {
@@ -610,6 +616,7 @@ thermostat_init(void)
 	if (of_dev == NULL) {
 		printk(KERN_ERR "Can't register temperatures device !\n");
+		of_node_put(np);
 		return -ENODEV;
BtrLinux
Privacy Overview
