[POWERPC] Add missing of_node_put in drivers/macintosh/smu.c
of_node_put is needed before discarding a value received from
of_find_node_by_type, eg in error handling code.
The semantic patch that makes the change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
struct device_node *n;
struct device_node *n1;
struct device_node *n2;
statement S;
identifier f1,f2;
expression E1,E2;
constant C;
n = of_find_node_by_type(...)
if (!n) S
... when != of_node_put(n)
    when != n1 = f1(n,...)
    when != E1 = n
    when any
    when strict
+ of_node_put(n);
  return -C;
  of_node_put(n);
  n2 = f2(n,...)
  E2 = n
  return ...;
Signed-off-by: Julia Lawall
Acked-by: Stephen Rothwell
Signed-off-by: Paul Mackerras
 drivers/macintosh/smu.c | 5 ++++-
 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/macintosh/smu.c b/drivers/macintosh/smu.c
index 77ad192..d86d57a 100644
--- a/drivers/macintosh/smu.c
+++ b/drivers/macintosh/smu.c
@@ -483,12 +483,15 @@ int __init smu_init (void)
 	if (smu_cmdbuf_abs == 0) {
 		printk(KERN_ERR "SMU: Command buffer not allocated !\n");
+		of_node_put(np);
 		return -EINVAL;
 	smu = alloc_bootmem(sizeof(struct smu_device));
-	if (smu == NULL)
+	if (smu == NULL) {
+		of_node_put(np);
 		return -ENOMEM;
 	memset(smu, 0, sizeof(*smu));
 	spin_lock_init(&smu->lock);
BtrLinux
Privacy Overview
