PowerPC-83xx: Deletion of an unnecessary check before the function call “of_node_put”
Author: Markus Elfring <elfring@users.sourceforge.net>
The of_node_put() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Scott Wood
 arch/powerpc/platforms/83xx/usb.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/powerpc/platforms/83xx/usb.c b/arch/powerpc/platforms/83xx/usb.c
index 1ad748b..5c31d82 100644
--- a/arch/powerpc/platforms/83xx/usb.c
+++ b/arch/powerpc/platforms/83xx/usb.c
@@ -162,8 +162,7 @@ int mpc831x_usb_cfg(void)
 	iounmap(immap);
-	if (immr_node)
-		of_node_put(immr_node);
+	of_node_put(immr_node);
 	/* Map USB SOC space */
 	ret = of_address_to_resource(np, 0, &res);
BtrLinux
Privacy Overview
