power_supply: charger-manager: add missing of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
for_each_child_of_node performs an of_node_get on each iteration, so
a break out of the loop requires an of_node_put.
The semantic patch that fixes this problem is as follows
(http://coccinelle.lip6.fr):
expression root,e;
local idexpression child;
 for_each_child_of_node(root, child) {
   ... when != of_node_put(child)
       when != e = child
   return child;
+  of_node_put(child);
?  return ...;
Signed-off-by: Julia Lawall
Reviewed-by: Krzysztof Kozlowski
Signed-off-by: Sebastian Reichel
 drivers/power/charger-manager.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/power/charger-manager.c b/drivers/power/charger-manager.c
index 907293e..1ea5d1a 100644
--- a/drivers/power/charger-manager.c
+++ b/drivers/power/charger-manager.c
@@ -1581,8 +1581,10 @@ static struct charger_desc *of_cm_parse_desc(struct device *dev)
 				cables = devm_kzalloc(dev, sizeof(*cables)
 						* chg_regs->num_cables,
 						GFP_KERNEL);
-				if (!cables)
+				if (!cables) {
 					return ERR_PTR(-ENOMEM);
 				chg_regs->cables = cables;
BtrLinux
Privacy Overview
