power: max77693: fix platform_no_drv_owner.cocci warnings
Author: kbuild test robot <fengguang.wu@intel.com>
drivers/power/max77693_charger.c:747:3-8: No need to set .owner here. The core will do it.
 Remove .owner field if calls are used which set it automatically
Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci
CC: Krzysztof Kozlowski
Signed-off-by: Fengguang Wu
Reviewed-by: Krzysztof Kozlowski
Signed-off-by: Sebastian Reichel
 drivers/power/max77693_charger.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/drivers/power/max77693_charger.c b/drivers/power/max77693_charger.c
index 841047c..b042970 100644
--- a/drivers/power/max77693_charger.c
+++ b/drivers/power/max77693_charger.c
@@ -740,7 +740,6 @@ MODULE_DEVICE_TABLE(platform, max77693_charger_id);
 static struct platform_driver max77693_charger_driver = {
 	.driver = {
-		.owner	= THIS_MODULE,
 		.name	= "max77693-charger",
 	.probe		= max77693_charger_probe,
BtrLinux
Privacy Overview
