PM-wakeup: Delete unnecessary checks before three function calls
Author: Markus Elfring <elfring@users.sourceforge.net>
The following functions test whether their argument is NULL
and then return immediately.
 * dev_pm_arm_wake_irq
 * dev_pm_disarm_wake_irq
 * wakeup_source_unregister
Thus the test around the calls is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Acked-by: Pavel Machek
[ rjw: Minor whitespace adjustments ]
Signed-off-by: Rafael J. Wysocki
 drivers/base/power/wakeup.c | 18 +++++++-----------
 1 file changed, 7 insertions(+), 11 deletions(-)
diff --git a/drivers/base/power/wakeup.c b/drivers/base/power/wakeup.c
index 5fb7718..62e4de2 100644
--- a/drivers/base/power/wakeup.c
+++ b/drivers/base/power/wakeup.c
@@ -334,10 +334,9 @@ void device_wakeup_arm_wake_irqs(void)
 	struct wakeup_source *ws;
 	rcu_read_lock();
-	list_for_each_entry_rcu(ws, &wakeup_sources, entry) {
-		if (ws->wakeirq)
-			dev_pm_arm_wake_irq(ws->wakeirq);
+	list_for_each_entry_rcu(ws, &wakeup_sources, entry)
+		dev_pm_arm_wake_irq(ws->wakeirq);
 	rcu_read_unlock();
@@ -351,10 +350,9 @@ void device_wakeup_disarm_wake_irqs(void)
 	rcu_read_lock();
-		if (ws->wakeirq)
-			dev_pm_disarm_wake_irq(ws->wakeirq);
+		dev_pm_disarm_wake_irq(ws->wakeirq);
 	rcu_read_unlock();
@@ -390,9 +388,7 @@ int device_wakeup_disable(struct device *dev)
 		return -EINVAL;
 	ws = device_wakeup_detach(dev);
-	if (ws)
-		wakeup_source_unregister(ws);
+	wakeup_source_unregister(ws);
 	return 0;
 EXPORT_SYMBOL_GPL(device_wakeup_disable);
BtrLinux
Privacy Overview
