pinctrl/exynos: Use irq_set_handler_locked()
Author: Thomas Gleixner <tglx@linutronix.de>
Use irq_set_handler_locked() as it avoids a redundant lookup of the
irq descriptor.
Search and replacement was done with coccinelle.
Signed-off-by: Thomas Gleixner
Cc: Jiang Liu
Cc: Julia Lawall
Cc: Linus Walleij
Cc: linux-gpio@vger.kernel.org
drivers/pinctrl/samsung/pinctrl-exynos.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/pinctrl/samsung/pinctrl-exynos.c b/drivers/pinctrl/samsung/pinctrl-exynos.c
index 14b02fc..f402eff 100644
--- a/drivers/pinctrl/samsung/pinctrl-exynos.c
+++ b/drivers/pinctrl/samsung/pinctrl-exynos.c
@@ -148,9 +148,9 @@ static int exynos_irq_set_type(struct irq_data *irqd, unsigned int type)
if (type & IRQ_TYPE_EDGE_BOTH)
- __irq_set_handler_locked(irqd->irq, handle_edge_irq);
+ irq_set_handler_locked(irqd, handle_edge_irq);
else
- __irq_set_handler_locked(irqd->irq, handle_level_irq);
+ irq_set_handler_locked(irqd, handle_level_irq);
con = readl(d->virt_base + reg_con);
con &= ~(EXYNOS_EINT_CON_MASK << shift); |
else
