pinctrl/at91: Use irq_set_handler_locked()
Author: Thomas Gleixner <tglx@linutronix.de>
Use irq_set_handler_locked() as it avoids a redundant lookup of the
irq descriptor.
Search and replacement was done with coccinelle.
Signed-off-by: Thomas Gleixner
Cc: Jiang Liu
Cc: Julia Lawall
Cc: Linus Walleij
Cc: linux-gpio@vger.kernel.org
 drivers/pinctrl/pinctrl-at91.c | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/pinctrl/pinctrl-at91.c b/drivers/pinctrl/pinctrl-at91.c
index a082447..6cec3861 100644
--- a/drivers/pinctrl/pinctrl-at91.c
+++ b/drivers/pinctrl/pinctrl-at91.c
@@ -1444,22 +1444,22 @@ static int alt_gpio_irq_type(struct irq_data *d, unsigned type)
 	switch (type) {
 	case IRQ_TYPE_EDGE_RISING:
-		__irq_set_handler_locked(d->irq, handle_simple_irq);
+		irq_set_handler_locked(d, handle_simple_irq);
 		writel_relaxed(mask, pio + PIO_ESR);
 		writel_relaxed(mask, pio + PIO_REHLSR);
 		break;
 	case IRQ_TYPE_EDGE_FALLING:
 		writel_relaxed(mask, pio + PIO_FELLSR);
 		break;
 	case IRQ_TYPE_LEVEL_LOW:
-		__irq_set_handler_locked(d->irq, handle_level_irq);
+		irq_set_handler_locked(d, handle_level_irq);
 		writel_relaxed(mask, pio + PIO_LSR);
 		break;
 	case IRQ_TYPE_LEVEL_HIGH:
 		break;
@@ -1468,7 +1468,7 @@ static int alt_gpio_irq_type(struct irq_data *d, unsigned type)
 		 * disable additional interrupt modes:
 		 * fall back to default behavior
 		writel_relaxed(mask, pio + PIO_AIMDR);
 		return 0;
 	case IRQ_TYPE_NONE:
BtrLinux
Privacy Overview
