pinctrl/amd: Use irq_set_handler_locked()
Author: Thomas Gleixner <tglx@linutronix.de>
Use irq_set_handler_locked() as it avoids a redundant lookup of the
irq descriptor.
Search and replacement was done with coccinelle.
Signed-off-by: Thomas Gleixner
Cc: Jiang Liu
Cc: Julia Lawall
Cc: Linus Walleij
Cc: linux-gpio@vger.kernel.org
 drivers/pinctrl/pinctrl-amd.c | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/pinctrl/pinctrl-amd.c b/drivers/pinctrl/pinctrl-amd.c
index d8e3f7c..ef72a8a 100644
--- a/drivers/pinctrl/pinctrl-amd.c
+++ b/drivers/pinctrl/pinctrl-amd.c
@@ -420,7 +420,7 @@ static int amd_gpio_irq_set_type(struct irq_data *d, unsigned int type)
 		pin_reg &= ~(ACTIVE_LEVEL_MASK << ACTIVE_LEVEL_OFF);
 		pin_reg |= ACTIVE_HIGH << ACTIVE_LEVEL_OFF;
 		pin_reg |= DB_TYPE_REMOVE_GLITCH << DB_CNTRL_OFF;
-		__irq_set_handler_locked(d->irq, handle_edge_irq);
+		irq_set_handler_locked(d, handle_edge_irq);
 		break;
 	case IRQ_TYPE_EDGE_FALLING:
@@ -428,7 +428,7 @@ static int amd_gpio_irq_set_type(struct irq_data *d, unsigned int type)
 		pin_reg |= ACTIVE_LOW << ACTIVE_LEVEL_OFF;
 		break;
 	case IRQ_TYPE_EDGE_BOTH:
@@ -436,7 +436,7 @@ static int amd_gpio_irq_set_type(struct irq_data *d, unsigned int type)
 		pin_reg |= BOTH_EADGE << ACTIVE_LEVEL_OFF;
 		break;
 	case IRQ_TYPE_LEVEL_HIGH:
@@ -445,7 +445,7 @@ static int amd_gpio_irq_set_type(struct irq_data *d, unsigned int type)
 		pin_reg &= ~(DB_CNTRl_MASK << DB_CNTRL_OFF);
 		pin_reg |= DB_TYPE_PRESERVE_LOW_GLITCH << DB_CNTRL_OFF;
-		__irq_set_handler_locked(d->irq, handle_level_irq);
+		irq_set_handler_locked(d, handle_level_irq);
 		break;
 	case IRQ_TYPE_LEVEL_LOW:
@@ -454,7 +454,7 @@ static int amd_gpio_irq_set_type(struct irq_data *d, unsigned int type)
 		pin_reg |= DB_TYPE_PRESERVE_HIGH_GLITCH << DB_CNTRL_OFF;
 		break;
 	case IRQ_TYPE_NONE:
BtrLinux
Privacy Overview
