pinctrl: sirf: atlas7: Add missing of_node_put
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
of_find_node_by_name does an of_node_get on its return value,
so an of_node_put is needed on this value before the corresponding
variable goes out of scope.
The Coccinelle semantic patch used to make this change is as follows:
struct device_node *n;
struct device_node *n1;
statement S;
identifier f;
expression E;
constant C;
n = of_find_node_by_name(...)
if (!n) S
... when != of_node_put(n)
    when != n1 = f(n,...)
    when != E = n
    when any
    when strict
+ of_node_put(n);
  return -C;
  of_node_put(n);
  n1 = f(n,...)
  E = n
  return ...;
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: Linus Walleij
 drivers/pinctrl/sirf/pinctrl-atlas7.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/pinctrl/sirf/pinctrl-atlas7.c b/drivers/pinctrl/sirf/pinctrl-atlas7.c
index 168c0f5..19952f7 100644
--- a/drivers/pinctrl/sirf/pinctrl-atlas7.c
+++ b/drivers/pinctrl/sirf/pinctrl-atlas7.c
@@ -5424,8 +5424,10 @@ static int atlas7_pinmux_probe(struct platform_device *pdev)
 	if (ret)
 		return ret;
 	pmx->sys2pci_base = devm_ioremap_resource(&pdev->dev, &res);
-	if (IS_ERR(pmx->sys2pci_base))
+	if (IS_ERR(pmx->sys2pci_base)) {
+		of_node_put(sys2pci_np);
 		return -ENOMEM;
 	pmx->dev = &pdev->dev;
BtrLinux
Privacy Overview
