pinctrl: nomadik: simplify use of devm_ioremap_resource
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Remove unneeded error handling on the result of a call to
platform_get_resource when the value is passed to devm_ioremap_resource.
Move the call to platform_get_resource adjacent to the call to
devm_ioremap_resource to make the connection between them more clear.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression pdev,res,n,e,e1;
expression ret != 0;
identifier l;
- res = platform_get_resource(pdev, IORESOURCE_MEM, n);
... when != res
- if (res == NULL) { ... \(goto l;\|return ret;\) }
... when != res
+ res = platform_get_resource(pdev, IORESOURCE_MEM, n);
e = devm_ioremap_resource(e1, res);
Signed-off-by: Julia Lawall
Signed-off-by: Linus Walleij
drivers/pinctrl/pinctrl-nomadik.c | 5 +----
1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/pinctrl/pinctrl-nomadik.c b/drivers/pinctrl/pinctrl-nomadik.c
index a8b8a53..f7c7279 100644
--- a/drivers/pinctrl/pinctrl-nomadik.c
+++ b/drivers/pinctrl/pinctrl-nomadik.c
@@ -1055,10 +1055,6 @@ static int nmk_gpio_probe(struct platform_device *dev)
pdata->num_gpio = NMK_GPIO_PER_CHIP;
- res = platform_get_resource(dev, IORESOURCE_MEM, 0);
- if (!res)
- return -ENOENT;
irq = platform_get_irq(dev, 0);
if (irq < 0)
return irq;
@@ -1067,6 +1063,7 @@ static int nmk_gpio_probe(struct platform_device *dev)
if (secondary_irq >= 0 && !pdata->get_secondary_status)
return -EINVAL;
+ res = platform_get_resource(dev, IORESOURCE_MEM, 0);
base = devm_ioremap_resource(&dev->dev, res);
if (IS_ERR(base))
return PTR_ERR(base); |
- if (!res)
- return -ENOENT;
if (irq < 0)
return irq;
return -EINVAL;
if (IS_ERR(base))
