pinctrl: mediatek: fix handling return value of mtk_pmx_find_gpio_mode
Author: Andrzej Hajda <a.hajda@samsung.com>
The function can return negative values, so its result should
be assigned to signed variable.
The problem has been detected using coccinelle semantic patch
scripts/coccinelle/tests/assign_signed_to_unsigned.cocci.
Fixes: 59ee9c9 ('pinctrl: mediatek: Add gpio_request_enable support')
Signed-off-by: Andrzej Hajda
Acked-by: Hongzhou Yang
Signed-off-by: Linus Walleij
 drivers/pinctrl/mediatek/pinctrl-mtk-common.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pinctrl/mediatek/pinctrl-mtk-common.c b/drivers/pinctrl/mediatek/pinctrl-mtk-common.c
index b752f5a..6024483 100644
--- a/drivers/pinctrl/mediatek/pinctrl-mtk-common.c
+++ b/drivers/pinctrl/mediatek/pinctrl-mtk-common.c
@@ -753,7 +753,7 @@ static int mtk_pmx_gpio_request_enable(struct pinctrl_dev *pctldev,
 				    struct pinctrl_gpio_range *range,
 				    unsigned offset)
-	unsigned long muxval;
+	int muxval;
 	struct mtk_pinctrl *pctl = pinctrl_dev_get_drvdata(pctldev);
 	muxval = mtk_pmx_find_gpio_mode(pctl, offset);
BtrLinux
Privacy Overview
