phy: miphy365x: add missing of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
for_each_child_of_node performs an of_node_get on each iteration,
so a return from the middle of the loop requires an of_node_put.
A simplified version of the semantic patch that finds this problem is as
follows (http://coccinelle.lip6.fr):
expression root,e;
local idexpression child;
 for_each_child_of_node(root, child) {
   ... when != of_node_put(child)
       when != e = child
   return child;
*  return ...;
Signed-off-by: Julia Lawall
Signed-off-by: Kishon Vijay Abraham I
 drivers/phy/phy-miphy365x.c | 16 +++++++++++-----
 1 file changed, 11 insertions(+), 5 deletions(-)
diff --git a/drivers/phy/phy-miphy365x.c b/drivers/phy/phy-miphy365x.c
index 00a686a..e661f3b 100644
--- a/drivers/phy/phy-miphy365x.c
+++ b/drivers/phy/phy-miphy365x.c
@@ -566,22 +566,25 @@ static int miphy365x_probe(struct platform_device *pdev)
 		miphy_phy = devm_kzalloc(&pdev->dev, sizeof(*miphy_phy),
 					 GFP_KERNEL);
-		if (!miphy_phy)
-			return -ENOMEM;
+		if (!miphy_phy) {
+			ret = -ENOMEM;
+			goto put_child;
 		miphy_dev->phys[port] = miphy_phy;
 		phy = devm_phy_create(&pdev->dev, child, &miphy365x_ops);
 		if (IS_ERR(phy)) {
 			dev_err(&pdev->dev, "failed to create PHY\n");
-			return PTR_ERR(phy);
+			ret = PTR_ERR(phy);
+			goto put_child;
 		miphy_dev->phys[port]->phy = phy;
 		ret = miphy365x_of_probe(child, miphy_phy);
 		if (ret)
-			return ret;
+			goto put_child;
 		phy_set_drvdata(phy, miphy_dev->phys[port]);
@@ -591,12 +594,15 @@ static int miphy365x_probe(struct platform_device *pdev)
 					&miphy_phy->ctrlreg);
 		if (ret) {
 			dev_err(&pdev->dev, "No sysconfig offset found\n");
-			return ret;
+			goto put_child;
 	provider = devm_of_phy_provider_register(&pdev->dev, miphy365x_xlate);
 	return PTR_ERR_OR_ZERO(provider);
+put_child:
+	of_node_put(child);
+	return ret;
 static const struct of_device_id miphy365x_of_match[] = {
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
