phy: miphy28lp: add missing of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
for_each_child_of_node performs an of_node_get on each iteration,
so a return from the middle of the loop requires an of_node_put.
A simplified version of the semantic patch that finds this problem is as
follows (http://coccinelle.lip6.fr):
expression root,e;
local idexpression child;
for_each_child_of_node(root, child) {
... when != of_node_put(child)
when != e = child
return child;
* return ...;
Signed-off-by: Julia Lawall
Signed-off-by: Kishon Vijay Abraham I
drivers/phy/phy-miphy28lp.c | 16 +++++++++++-----
1 file changed, 11 insertions(+), 5 deletions(-)
diff --git a/drivers/phy/phy-miphy28lp.c b/drivers/phy/phy-miphy28lp.c
index c47b56b..3acd2a1 100644
--- a/drivers/phy/phy-miphy28lp.c
+++ b/drivers/phy/phy-miphy28lp.c
@@ -1226,15 +1226,18 @@ static int miphy28lp_probe(struct platform_device *pdev)
miphy_phy = devm_kzalloc(&pdev->dev, sizeof(*miphy_phy),
GFP_KERNEL);
- if (!miphy_phy)
- return -ENOMEM;
+ if (!miphy_phy) {
+ ret = -ENOMEM;
+ goto put_child;
miphy_dev->phys[port] = miphy_phy;
phy = devm_phy_create(&pdev->dev, child, &miphy28lp_ops);
if (IS_ERR(phy)) {
dev_err(&pdev->dev, "failed to create PHY\n");
- return PTR_ERR(phy);
+ ret = PTR_ERR(phy);
+ goto put_child;
miphy_dev->phys[port]->phy = phy;
@@ -1242,11 +1245,11 @@ static int miphy28lp_probe(struct platform_device *pdev)
ret = miphy28lp_of_probe(child, miphy_phy);
if (ret)
- return ret;
+ goto put_child;
ret = miphy28lp_probe_resets(child, miphy_dev->phys[port]);
if (ret)
- return ret;
+ goto put_child;
phy_set_drvdata(phy, miphy_dev->phys[port]);
port++;
@@ -1255,6 +1258,9 @@ static int miphy28lp_probe(struct platform_device *pdev)
provider = devm_of_phy_provider_register(&pdev->dev, miphy28lp_xlate);
return PTR_ERR_OR_ZERO(provider);
+put_child:
+ of_node_put(child);
+ return ret;
static const struct of_device_id miphy28lp_of_match[] = { |
GFP_KERNEL);
- if (!miphy_phy)
- return -ENOMEM;
+ if (!miphy_phy) {
+ ret = -ENOMEM;
+ goto put_child;
if (IS_ERR(phy)) {
+ goto put_child;
if (ret)
- return ret;
+ goto put_child;
if (ret)
- return ret;
+ goto put_child;
port++;
+put_child:
+ return ret;
