perf/x86/intel/uncore: Delete an unnecessary check before pci_dev_put() call
Author: Markus Elfring <elfring@users.sourceforge.net>
The pci_dev_put() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Peter Zijlstra (Intel)
Cc: Arnaldo Carvalho de Melo
Cc: H. Peter Anvin
Cc: Linus Torvalds
Link: http://lkml.kernel.org/r/54D0B59C.2060106@users.sourceforge.net
Signed-off-by: Ingo Molnar
 arch/x86/kernel/cpu/perf_event_intel_uncore_snbep.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/x86/kernel/cpu/perf_event_intel_uncore_snbep.c b/arch/x86/kernel/cpu/perf_event_intel_uncore_snbep.c
index 21af6149e..12d9548 100644
--- a/arch/x86/kernel/cpu/perf_event_intel_uncore_snbep.c
+++ b/arch/x86/kernel/cpu/perf_event_intel_uncore_snbep.c
@@ -1132,8 +1132,7 @@ static int snbep_pci2phy_map_init(int devid)
-	if (ubox_dev)
-		pci_dev_put(ubox_dev);
+	pci_dev_put(ubox_dev);
 	return err ? pcibios_err_to_errno(err) : 0;
BtrLinux
Privacy Overview
