perf/core: Replace rcu_assign_pointer() with RCU_INIT_POINTER()
Author: Andreea-Cristina Bernat <bernat.ada@gmail.com>
The use of "rcu_assign_pointer()" is NULLing out the pointer.
According to RCU_INIT_POINTER()'s block comment:
  "1.   This use of RCU_INIT_POINTER() is NULLing out the pointer"
it is better to use it instead of rcu_assign_pointer() because it has a
smaller overhead.
The following Coccinelle semantic patch was used:
  - rcu_assign_pointer
  + RCU_INIT_POINTER
    (..., NULL)
Signed-off-by: Andreea-Cristina Bernat
Signed-off-by: Peter Zijlstra (Intel)
Cc: Arnaldo Carvalho de Melo
Link: http://lkml.kernel.org/r/20140822132605.GA20130@ada
Signed-off-by: Ingo Molnar
 kernel/events/core.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/kernel/events/core.c b/kernel/events/core.c
index 01bd42e..f917dec 100644
--- a/kernel/events/core.c
+++ b/kernel/events/core.c
@@ -5908,7 +5908,7 @@ static void swevent_hlist_release(struct swevent_htable *swhash)
 	if (!hlist)
 		return;
-	rcu_assign_pointer(swhash->swevent_hlist, NULL);
+	RCU_INIT_POINTER(swhash->swevent_hlist, NULL);
 	kfree_rcu(hlist, rcu_head);
BtrLinux
Privacy Overview
