perf tools: Fix handling read result using a signed variable
Author: Andrzej Hajda <a.hajda@samsung.com>
The function can return negative value, assigning it to unsigned
variable can cause memory corruption.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2038576
Signed-off-by: Andrzej Hajda
Cc: Bartlomiej Zolnierkiewicz
Cc: Marek Szyprowski
Cc: Peter Zijlstra
Cc: kernel-janitors@vger.kernel.org
Link: http://lkml.kernel.org/r/1444122017-16856-1-git-send-email-a.hajda@samsung.com
Signed-off-by: Arnaldo Carvalho de Melo
 tools/perf/util/event.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/tools/perf/util/event.c b/tools/perf/util/event.c
index cb98b5a..8b10621 100644
--- a/tools/perf/util/event.c
+++ b/tools/perf/util/event.c
@@ -67,7 +67,8 @@ static int perf_event__get_comm_ids(pid_t pid, char *comm, size_t len,
 	char filename[PATH_MAX];
 	char bf[4096];
 	int fd;
-	size_t size = 0, n;
+	size_t size = 0;
+	ssize_t n;
 	char *nl, *name, *tgids, *ppids;
 	*tgid = -1;
BtrLinux
Privacy Overview
