perf tests: Do not use sizeof on pointer type
Author: Vaishali Thakkar <vaishali.thakkar@oracle.com>
Using sizeof on a malloced pointer type will return the wordsize which
can often cause one to allocate a buffer much smaller than it is needed.
So, here do not use sizeof on pointer type.
Note that this has no effect on runtime because 'dsos' is a pointer to a
pointer.
Problem found using Coccinelle.
Signed-off-by: Vaishali Thakkar
Cc: Alexander Shishkin
Cc: Peter Zijlstra
Link: http://lkml.kernel.org/r/1461862017-23358-1-git-send-email-vaishali.thakkar@oracle.com
Signed-off-by: Arnaldo Carvalho de Melo
 tools/perf/tests/dso-data.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/perf/tests/dso-data.c b/tools/perf/tests/dso-data.c
index dc673ff..8cf0d9e 100644
--- a/tools/perf/tests/dso-data.c
+++ b/tools/perf/tests/dso-data.c
@@ -202,7 +202,7 @@ static int dsos__create(int cnt, int size)
 	int i;
-	dsos = malloc(sizeof(dsos) * cnt);
+	dsos = malloc(sizeof(*dsos) * cnt);
 	TEST_ASSERT_VAL("failed to alloc dsos array", dsos);
 	for (i = 0; i < cnt; i++) {
BtrLinux
Privacy Overview
