arch/arm/mach-iop13xx/msi.c | 8 ++++----
arch/ia64/kernel/msi_ia64.c | 4 ++--
arch/ia64/sn/kernel/msi_sn.c | 4 ++--
arch/mips/pci/msi-xlp.c | 8 ++++----
arch/powerpc/platforms/cell/axon_msi.c | 6 +++---
arch/powerpc/sysdev/fsl_msi.c | 4 ++--
arch/powerpc/sysdev/mpic_pasemi_msi.c | 4 ++--
arch/powerpc/sysdev/mpic_u3msi.c | 4 ++--
arch/powerpc/sysdev/xics/ics-opal.c | 2 +-
arch/powerpc/sysdev/xics/ics-rtas.c | 2 +-
arch/s390/pci/pci.c | 4 ++--
arch/sparc/kernel/pci_msi.c | 8 ++++----
arch/tile/kernel/pci_gx.c | 6 +++---
arch/x86/kernel/apic/io_apic.c | 4 ++--
drivers/irqchip/irq-armada-370-xp.c | 8 ++++----
drivers/pci/host/pci-keystone-dw.c | 4 ++--
drivers/pci/host/pci-tegra.c | 8 ++++----
drivers/pci/host/pcie-designware.c | 8 ++++----
drivers/pci/host/pcie-rcar.c | 8 ++++----
drivers/pci/host/pcie-xilinx.c | 8 ++++----
20 files changed, 56 insertions(+), 56 deletions(-)
diff --git a/arch/arm/mach-iop13xx/msi.c b/arch/arm/mach-iop13xx/msi.c
index 3f7739c..9f89e76 100644
--- a/arch/arm/mach-iop13xx/msi.c
+++ b/arch/arm/mach-iop13xx/msi.c
@@ -126,10 +126,10 @@ static void iop13xx_msi_nop(struct irq_data *d)
static struct irq_chip iop13xx_msi_chip = {
.name = "PCI-MSI",
.irq_ack = iop13xx_msi_nop,
- .irq_enable = unmask_msi_irq,
- .irq_disable = mask_msi_irq,
- .irq_mask = mask_msi_irq,
- .irq_unmask = unmask_msi_irq,
+ .irq_enable = pci_msi_unmask_irq,
+ .irq_disable = pci_msi_mask_irq,
+ .irq_mask = pci_msi_mask_irq,
+ .irq_unmask = pci_msi_unmask_irq,
int arch_setup_msi_irq(struct pci_dev *pdev, struct msi_desc *desc)
diff --git a/arch/ia64/kernel/msi_ia64.c b/arch/ia64/kernel/msi_ia64.c
index 35b10dd..8ae36ea 100644
--- a/arch/ia64/kernel/msi_ia64.c
+++ b/arch/ia64/kernel/msi_ia64.c
@@ -102,8 +102,8 @@ static int ia64_msi_retrigger_irq(struct irq_data *data)
static struct irq_chip ia64_msi_chip = {
.name = "PCI-MSI",
.irq_ack = ia64_ack_msi_irq,
#ifdef CONFIG_SMP
.irq_set_affinity = ia64_set_msi_irq_affinity,
diff --git a/arch/ia64/sn/kernel/msi_sn.c b/arch/ia64/sn/kernel/msi_sn.c
index 433cafe..a0eb27b 100644
--- a/arch/ia64/sn/kernel/msi_sn.c
+++ b/arch/ia64/sn/kernel/msi_sn.c
@@ -228,8 +228,8 @@ static int sn_msi_retrigger_irq(struct irq_data *data)
static struct irq_chip sn_msi_chip = {
.name = "PCI-MSI",
.irq_ack = sn_ack_msi_irq,
#ifdef CONFIG_SMP
.irq_set_affinity = sn_set_msi_irq_affinity,
diff --git a/arch/mips/pci/msi-xlp.c b/arch/mips/pci/msi-xlp.c
index 81ea2b4..aa7dea3e 100644
--- a/arch/mips/pci/msi-xlp.c
+++ b/arch/mips/pci/msi-xlp.c
@@ -217,7 +217,7 @@ static void xlp_msix_mask_ack(struct irq_data *d)
msixvec = nlm_irq_msixvec(d->irq);
link = nlm_irq_msixlink(msixvec);
- mask_msi_irq(d);
+ pci_msi_mask_irq(d);
md = irq_data_get_irq_handler_data(d);
/* Ack MSI on bridge */
@@ -239,10 +239,10 @@ static void xlp_msix_mask_ack(struct irq_data *d)
static struct irq_chip xlp_msix_chip = {
.name = "XLP-MSIX",
.irq_mask_ack = xlp_msix_mask_ack,
void arch_teardown_msi_irq(unsigned int irq)
diff --git a/arch/powerpc/platforms/cell/axon_msi.c b/arch/powerpc/platforms/cell/axon_msi.c
index 26fa343..0883994 100644
--- a/arch/powerpc/platforms/cell/axon_msi.c
+++ b/arch/powerpc/platforms/cell/axon_msi.c
@@ -301,9 +301,9 @@ static void axon_msi_teardown_msi_irqs(struct pci_dev *dev)
static struct irq_chip msic_irq_chip = {
- .irq_shutdown = mask_msi_irq,
+ .irq_shutdown = pci_msi_mask_irq,
.name = "AXON-MSI",
diff --git a/arch/powerpc/sysdev/fsl_msi.c b/arch/powerpc/sysdev/fsl_msi.c
index bd5a9f7..19d4b2c 100644
--- a/arch/powerpc/sysdev/fsl_msi.c
+++ b/arch/powerpc/sysdev/fsl_msi.c
@@ -82,8 +82,8 @@ static void fsl_msi_print_chip(struct irq_data *irqd, struct seq_file *p)
static struct irq_chip fsl_msi_chip = {
.irq_ack = fsl_msi_end_irq,
.irq_print_chip = fsl_msi_print_chip,
diff --git a/arch/powerpc/sysdev/mpic_pasemi_msi.c b/arch/powerpc/sysdev/mpic_pasemi_msi.c
index 45a6f40..45c114b 100644
--- a/arch/powerpc/sysdev/mpic_pasemi_msi.c
+++ b/arch/powerpc/sysdev/mpic_pasemi_msi.c
@@ -42,7 +42,7 @@ static struct mpic *msi_mpic;
static void mpic_pasemi_msi_mask_irq(struct irq_data *data)
pr_debug("mpic_pasemi_msi_mask_irq %d\n", data->irq);
- mask_msi_irq(data);
+ pci_msi_mask_irq(data);
mpic_mask_irq(data);
@@ -50,7 +50,7 @@ static void mpic_pasemi_msi_unmask_irq(struct irq_data *data)
pr_debug("mpic_pasemi_msi_unmask_irq %d\n", data->irq);
mpic_unmask_irq(data);
- unmask_msi_irq(data);
+ pci_msi_unmask_irq(data);
static struct irq_chip mpic_pasemi_msi_chip = {
diff --git a/arch/powerpc/sysdev/mpic_u3msi.c b/arch/powerpc/sysdev/mpic_u3msi.c
index ac6f1f9..0dff1cd 100644
--- a/arch/powerpc/sysdev/mpic_u3msi.c
+++ b/arch/powerpc/sysdev/mpic_u3msi.c
@@ -25,14 +25,14 @@ static struct mpic *msi_mpic;
static void mpic_u3msi_mask_irq(struct irq_data *data)
static void mpic_u3msi_unmask_irq(struct irq_data *data)
static struct irq_chip mpic_u3msi_chip = {
diff --git a/arch/powerpc/sysdev/xics/ics-opal.c b/arch/powerpc/sysdev/xics/ics-opal.c
index 3c6ee1b..4ba554e 100644
--- a/arch/powerpc/sysdev/xics/ics-opal.c
+++ b/arch/powerpc/sysdev/xics/ics-opal.c
@@ -73,7 +73,7 @@ static unsigned int ics_opal_startup(struct irq_data *d)
* at that level, so we do it here by hand.
if (d->msi_desc)
- unmask_msi_irq(d);
+ pci_msi_unmask_irq(d);
#endif
/* unmask it */
diff --git a/arch/powerpc/sysdev/xics/ics-rtas.c b/arch/powerpc/sysdev/xics/ics-rtas.c
index 936575d..bc81335b 100644
--- a/arch/powerpc/sysdev/xics/ics-rtas.c
+++ b/arch/powerpc/sysdev/xics/ics-rtas.c
@@ -76,7 +76,7 @@ static unsigned int ics_rtas_startup(struct irq_data *d)
if (d->msi_desc)
#endif
/* unmask it */
ics_rtas_unmask_irq(d);
diff --git a/arch/s390/pci/pci.c b/arch/s390/pci/pci.c
index fb54bbd..d59c825 100644
--- a/arch/s390/pci/pci.c
+++ b/arch/s390/pci/pci.c
@@ -50,8 +50,8 @@ static DEFINE_SPINLOCK(zpci_list_lock);
static struct irq_chip zpci_irq_chip = {
.name = "zPCI",
static DECLARE_BITMAP(zpci_domain, ZPCI_NR_DEVICES);
diff --git a/arch/sparc/kernel/pci_msi.c b/arch/sparc/kernel/pci_msi.c
index 73db0ed..84e16d8 100644
--- a/arch/sparc/kernel/pci_msi.c
+++ b/arch/sparc/kernel/pci_msi.c
@@ -111,10 +111,10 @@ static void free_msi(struct pci_pbm_info *pbm, int msi_num)
static struct irq_chip msi_irq = {
.name = "PCI-MSI",
/* XXX affinity XXX */
diff --git a/arch/tile/kernel/pci_gx.c b/arch/tile/kernel/pci_gx.c
index 376d9f1..e717af20 100644
--- a/arch/tile/kernel/pci_gx.c
+++ b/arch/tile/kernel/pci_gx.c
@@ -1453,7 +1453,7 @@ static struct pci_ops tile_cfg_ops = {
static unsigned int tilegx_msi_startup(struct irq_data *d)
if (d->msi_desc)
return 0;
@@ -1465,14 +1465,14 @@ static void tilegx_msi_ack(struct irq_data *d)
static void tilegx_msi_mask(struct irq_data *d)
- mask_msi_irq(d);
__insn_mtspr(SPR_IPI_MASK_SET_K, 1UL << d->irq);
static void tilegx_msi_unmask(struct irq_data *d)
__insn_mtspr(SPR_IPI_MASK_RESET_K, 1UL << d->irq);
static struct irq_chip tilegx_msi_chip = {
diff --git a/arch/x86/kernel/apic/io_apic.c b/arch/x86/kernel/apic/io_apic.c
index d775aef..7ffe0a2 100644
--- a/arch/x86/kernel/apic/io_apic.c
+++ b/arch/x86/kernel/apic/io_apic.c
@@ -3169,8 +3169,8 @@ msi_set_affinity(struct irq_data *data, const struct cpumask *mask, bool force)
static struct irq_chip msi_chip = {
.name = "PCI-MSI",
.irq_ack = ack_apic_edge,
.irq_set_affinity = msi_set_affinity,
.irq_retrigger = ioapic_retrigger_irq,
diff --git a/drivers/irqchip/irq-armada-370-xp.c b/drivers/irqchip/irq-armada-370-xp.c
index 8c7f077..1aeffca 100644
--- a/drivers/irqchip/irq-armada-370-xp.c
+++ b/drivers/irqchip/irq-armada-370-xp.c
@@ -172,10 +172,10 @@ static void armada_370_xp_teardown_msi_irq(struct msi_controller *chip,
static struct irq_chip armada_370_xp_msi_irq_chip = {
.name = "armada_370_xp_msi_irq",
static int armada_370_xp_msi_map(struct irq_domain *domain, unsigned int virq,
diff --git a/drivers/pci/host/pci-keystone-dw.c b/drivers/pci/host/pci-keystone-dw.c
index ac3d08c..313338db 100644
--- a/drivers/pci/host/pci-keystone-dw.c
+++ b/drivers/pci/host/pci-keystone-dw.c
@@ -155,7 +155,7 @@ static void ks_dw_pcie_msi_irq_mask(struct irq_data *d)
/* Mask the end point if PVM implemented */
if (IS_ENABLED(CONFIG_PCI_MSI)) {
if (msi->msi_attrib.maskbit)
- mask_msi_irq(d);
ks_dw_pcie_msi_clear_irq(pp, offset);
@@ -177,7 +177,7 @@ static void ks_dw_pcie_msi_irq_unmask(struct irq_data *d)
ks_dw_pcie_msi_set_irq(pp, offset);
diff --git a/drivers/pci/host/pci-tegra.c b/drivers/pci/host/pci-tegra.c
index 3184171..adee80b 100644
--- a/drivers/pci/host/pci-tegra.c
+++ b/drivers/pci/host/pci-tegra.c
@@ -1317,10 +1317,10 @@ static void tegra_msi_teardown_irq(struct msi_controller *chip,
static struct irq_chip tegra_msi_irq_chip = {
.name = "Tegra PCIe MSI",
static int tegra_msi_map(struct irq_domain *domain, unsigned int irq,
diff --git a/drivers/pci/host/pcie-designware.c b/drivers/pci/host/pcie-designware.c
index e03f4e7..17b5155 100644
--- a/drivers/pci/host/pcie-designware.c
+++ b/drivers/pci/host/pcie-designware.c
@@ -152,10 +152,10 @@ static int dw_pcie_wr_own_conf(struct pcie_port *pp, int where, int size,
static struct irq_chip dw_msi_irq_chip = {
.name = "PCI-MSI",
/* MSI int handler */
diff --git a/drivers/pci/host/pcie-rcar.c b/drivers/pci/host/pcie-rcar.c
index c1177cd..d3053e5 100644
--- a/drivers/pci/host/pcie-rcar.c
+++ b/drivers/pci/host/pcie-rcar.c
@@ -655,10 +655,10 @@ static void rcar_msi_teardown_irq(struct msi_controller *chip, unsigned int irq)
static struct irq_chip rcar_msi_irq_chip = {
.name = "R-Car PCIe MSI",
static int rcar_msi_map(struct irq_domain *domain, unsigned int irq,
diff --git a/drivers/pci/host/pcie-xilinx.c b/drivers/pci/host/pcie-xilinx.c
index 6768338..2f50fa5 100644
--- a/drivers/pci/host/pcie-xilinx.c
+++ b/drivers/pci/host/pcie-xilinx.c
@@ -389,10 +389,10 @@ static struct msi_controller xilinx_pcie_msi_chip = {
/* HW Interrupt Chip Descriptor */
static struct irq_chip xilinx_msi_irq_chip = {
.name = "Xilinx PCIe MSI",
