PCI/keystone: Fix race in installing chained IRQ handler
Author: Thomas Gleixner <tglx@linutronix.de>
Fix a race where a pending interrupt could be received and the handler
called before the handler's data has been setup, by converting to
irq_set_chained_handler_and_data().
Search and conversion was done with coccinelle:
expression E1, E2, E3;
-if (irq_set_chained_handler(E1, E3) != 0)
-   BUG();
-irq_set_chained_handler(E1, E3);
-irq_set_handler_data(E1, E2);
+irq_set_chained_handler_and_data(E1, E3, E2);
-   BUG();
Reported-by: Russell King
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
Cc: Murali Karicheri
Cc: Bjorn Helgaas
Cc: linux-pci@vger.kernel.org
Cc: linux-arm-kernel@lists.infradead.org
 drivers/pci/host/pci-keystone.c | 7 +++----
 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/drivers/pci/host/pci-keystone.c b/drivers/pci/host/pci-keystone.c
index 75333b0..47cf0c1 100644
--- a/drivers/pci/host/pci-keystone.c
+++ b/drivers/pci/host/pci-keystone.c
@@ -223,10 +223,9 @@ static void ks_pcie_setup_interrupts(struct keystone_pcie *ks_pcie)
 	/* MSI IRQ */
 	if (IS_ENABLED(CONFIG_PCI_MSI)) {
 		for (i = 0; i < ks_pcie->num_msi_host_irqs; i++) {
-			irq_set_chained_handler(ks_pcie->msi_host_irqs[i],
-						ks_pcie_msi_irq_handler);
-			irq_set_handler_data(ks_pcie->msi_host_irqs[i],
-					     ks_pcie);
+			irq_set_chained_handler_and_data(ks_pcie->msi_host_irqs[i],
+							 ks_pcie_msi_irq_handler,
+							 ks_pcie);
BtrLinux
Privacy Overview
