PCI: shpchp: Constify hpc_ops structure
Author: Julia Lawall <Julia.Lawall@lip6.fr>
The hpc_ops structure is never modified, so declare it as const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall
Signed-off-by: Bjorn Helgaas
drivers/pci/hotplug/shpchp.h | 4 ++--
drivers/pci/hotplug/shpchp_hpc.c | 2 +-
2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/pci/hotplug/shpchp.h b/drivers/pci/hotplug/shpchp.h
index 821227f..4da8fc6 100644
--- a/drivers/pci/hotplug/shpchp.h
+++ b/drivers/pci/hotplug/shpchp.h
@@ -84,7 +84,7 @@ struct slot {
u8 presence_save;
u8 pwr_save;
struct controller *ctrl;
- struct hpc_ops *hpc_ops;
+ const struct hpc_ops *hpc_ops;
struct hotplug_slot *hotplug_slot;
struct list_head slot_list;
struct delayed_work work; /* work for button event */
@@ -106,7 +106,7 @@ struct controller {
int slot_num_inc; /* 1 or -1 */
struct pci_dev *pci_dev;
wait_queue_head_t queue; /* sleep & wake process */
u8 slot_device_offset;
u32 pcix_misc2_reg; /* for amd pogo errata */
diff --git a/drivers/pci/hotplug/shpchp_hpc.c b/drivers/pci/hotplug/shpchp_hpc.c
index e03341c..de0ea47 100644
--- a/drivers/pci/hotplug/shpchp_hpc.c
+++ b/drivers/pci/hotplug/shpchp_hpc.c
@@ -910,7 +910,7 @@ static int shpc_get_max_bus_speed(struct controller *ctrl)
return retval;
-static struct hpc_ops shpchp_hpc_ops = {
+static const struct hpc_ops shpchp_hpc_ops = {
.power_on_slot = hpc_power_on_slot,
.slot_enable = hpc_slot_enable,
.slot_disable = hpc_slot_disable, |
u8 presence_save;
u8 pwr_save;
return retval;
