PCI: keystone: Fix misspelling of current function in debug output
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Replace a misspelled function name by %s and then __func__.
The function name contains pcie, not pci as in the string.
This was done using Coccinelle, including the use of Levenshtein distance,
as proposed by Rasmus Villemoes.
Signed-off-by: Julia Lawall
Signed-off-by: Bjorn Helgaas
Acked-by: Murali Karicheri
drivers/pci/host/pci-keystone.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pci/host/pci-keystone.c b/drivers/pci/host/pci-keystone.c
index 23a1d97..75333b0 100644
--- a/drivers/pci/host/pci-keystone.c
+++ b/drivers/pci/host/pci-keystone.c
@@ -119,7 +119,7 @@ static void ks_pcie_msi_irq_handler(unsigned int irq, struct irq_desc *desc)
struct pcie_port *pp = &ks_pcie->pp;
struct irq_chip *chip = irq_desc_get_chip(desc);
- dev_dbg(pp->dev, "ks_pci_msi_irq_handler, irq %d\n", irq);
+ dev_dbg(pp->dev, "%s, irq %d\n", __func__, irq);
* The chained irq handler installation would have replaced normal |
