PCI: iproc: Delete unnecessary checks before phy calls
Author: Markus Elfring <elfring@users.sourceforge.net>
The functions phy_exit() and phy_power_off() test whether their argument is
NULL and then return immediately.  Thus the test around the calls is not
needed.
This issue was detected by using the Coccinelle software.
[bhelgaas: also phy_init() and phy_power_on(), as Ray Jui suggested]
[bhelgaas: also remove tests in iproc_pcie_remove()]
Signed-off-by: Markus Elfring
Signed-off-by: Bjorn Helgaas
Reviewed-by: Ray Jui
 drivers/pci/host/pcie-iproc.c | 34 +++++++++++++---------------------
 1 file changed, 13 insertions(+), 21 deletions(-)
diff --git a/drivers/pci/host/pcie-iproc.c b/drivers/pci/host/pcie-iproc.c
index d77481e..9a00dca 100644
--- a/drivers/pci/host/pcie-iproc.c
+++ b/drivers/pci/host/pcie-iproc.c
@@ -191,19 +191,16 @@ int iproc_pcie_setup(struct iproc_pcie *pcie, struct list_head *res)
 	if (!pcie || !pcie->dev || !pcie->base)
 		return -EINVAL;
-	if (pcie->phy) {
-		ret = phy_init(pcie->phy);
-		if (ret) {
-			dev_err(pcie->dev, "unable to initialize PCIe PHY\n");
-			return ret;
-		ret = phy_power_on(pcie->phy);
-		if (ret) {
-			dev_err(pcie->dev, "unable to power on PCIe PHY\n");
-			goto err_exit_phy;
+	ret = phy_init(pcie->phy);
+	if (ret) {
+		dev_err(pcie->dev, "unable to initialize PCIe PHY\n");
+		return ret;
+	ret = phy_power_on(pcie->phy);
+	if (ret) {
+		dev_err(pcie->dev, "unable to power on PCIe PHY\n");
+		goto err_exit_phy;
 	iproc_pcie_reset(pcie);
@@ -239,12 +236,9 @@ err_rm_root_bus:
 	pci_remove_root_bus(bus);
 err_power_off_phy:
-	if (pcie->phy)
-		phy_power_off(pcie->phy);
+	phy_power_off(pcie->phy);
 err_exit_phy:
-	if (pcie->phy)
-		phy_exit(pcie->phy);
+	phy_exit(pcie->phy);
 	return ret;
 EXPORT_SYMBOL(iproc_pcie_setup);
@@ -254,10 +248,8 @@ int iproc_pcie_remove(struct iproc_pcie *pcie)
 	pci_stop_root_bus(pcie->root_bus);
 	pci_remove_root_bus(pcie->root_bus);
-	if (pcie->phy) {
 	return 0;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
