PCI: imx6: Simplify a trivial if-return sequence
Author: Fabio Estevam <fabio.estevam@freescale.com>
Simplify a trivial if-return sequence by combining it with a preceding
function call.
The semantic patch that makes this change is available in
scripts/coccinelle/misc/simple_return.cocci.
Signed-off-by: Fabio Estevam
Signed-off-by: Bjorn Helgaas
CC: Lucas Stach
 drivers/pci/host/pci-imx6.c | 12 ++----------
 1 file changed, 2 insertions(+), 10 deletions(-)
diff --git a/drivers/pci/host/pci-imx6.c b/drivers/pci/host/pci-imx6.c
index 233a196..8f3a981 100644
--- a/drivers/pci/host/pci-imx6.c
+++ b/drivers/pci/host/pci-imx6.c
@@ -117,11 +117,7 @@ static int pcie_phy_wait_ack(void __iomem *dbi_base, int addr)
 	val = addr << PCIE_PHY_CTRL_DATA_LOC;
 	writel(val, dbi_base + PCIE_PHY_CTRL);
-	ret = pcie_phy_poll_ack(dbi_base, 0);
-	if (ret)
-		return ret;
-	return 0;
+	return pcie_phy_poll_ack(dbi_base, 0);
 /* Read from the 16-bit PCIe PHY control registers (not memory-mapped) */
@@ -148,11 +144,7 @@ static int pcie_phy_read(void __iomem *dbi_base, int addr , int *data)
 	/* deassert Read signal */
 	writel(0x00, dbi_base + PCIE_PHY_CTRL);
-	if (ret)
-		return ret;
-	return 0;
 static int pcie_phy_write(void __iomem *dbi_base, int addr, int data)
BtrLinux
Privacy Overview
