PCI: ibmphp: Remove unneeded NULL test
Author: Julia Lawall <julia.lawall@lip6.fr>
Remove unneeded NULL test. The index variable of list_for_each_entry is
never NULL, as it is the structure that contains the list pointer.
Generated by: scripts/coccinelle/iterators/itnull.cocci
Signed-off-by: Fengguang Wu
Signed-off-by: Julia Lawall
Signed-off-by: Bjorn Helgaas
CC: Geliang Tang
drivers/pci/hotplug/ibmphp_core.c | 3 ---
1 file changed, 3 deletions(-)
diff --git a/drivers/pci/hotplug/ibmphp_core.c b/drivers/pci/hotplug/ibmphp_core.c
index 010e46a..49adf22 100644
--- a/drivers/pci/hotplug/ibmphp_core.c
+++ b/drivers/pci/hotplug/ibmphp_core.c
@@ -503,9 +503,6 @@ static int __init init_ops(void)
int rc;
list_for_each_entry(slot_cur, &ibmphp_slot_head, ibm_slot_list) {
- if (!slot_cur)
- return -ENODEV;
debug("BEFORE GETTING SLOT STATUS, slot # %x\n",
slot_cur->number);
if (slot_cur->ctrl->revision == 0xFF) |
int rc;
- if (!slot_cur)
- return -ENODEV;
slot_cur->number);
