PCI hotplug: Use kmemdup
Use kmemdup when some other buffer is immediately copied into the
allocated region.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression from,to,size,flag;
statement S;
-  to = \(kmalloc\|kzalloc\)(size,flag);
+  to = kmemdup(from,size,flag);
   if (to==NULL || ...) S
-  memcpy(to, from, size);
Signed-off-by: Julia Lawall
Signed-off-by: Jesse Barnes
 drivers/pci/hotplug/cpqphp_core.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/pci/hotplug/cpqphp_core.c b/drivers/pci/hotplug/cpqphp_core.c
index f184d1d..cb7818f 100644
--- a/drivers/pci/hotplug/cpqphp_core.c
+++ b/drivers/pci/hotplug/cpqphp_core.c
@@ -1075,13 +1075,12 @@ static int cpqhpc_probe(struct pci_dev *pdev, const struct pci_device_id *ent)
 	/* make our own copy of the pci bus structure,
 	 * as we like tweaking it a lot */
-	ctrl->pci_bus = kmalloc(sizeof(*ctrl->pci_bus), GFP_KERNEL);
+	ctrl->pci_bus = kmemdup(pdev->bus, sizeof(*ctrl->pci_bus), GFP_KERNEL);
 	if (!ctrl->pci_bus) {
 		err("out of memory\n");
 		rc = -ENOMEM;
 		goto err_free_ctrl;
-	memcpy(ctrl->pci_bus, pdev->bus, sizeof(*ctrl->pci_bus));
 	ctrl->bus = pdev->bus->number;
 	ctrl->rev = pdev->revision;
