PCI: dra7xx: Remove unneeded use of IS_ERR_VALUE()
Author: Fabio Estevam <fabio.estevam@freescale.com>
There is no need to use the IS_ERR_VALUE() macro for checking the return
value from pm_runtime_* functions.
Test for a negative pm_runtime_get_sync() return value instead of using
IS_ERR_VALUE().
The semantic patch that makes this change is available in
scripts/coccinelle/api/pm_runtime.cocci.
Signed-off-by: Fabio Estevam
Signed-off-by: Bjorn Helgaas
CC: Kishon Vijay Abraham I
 drivers/pci/host/pci-dra7xx.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pci/host/pci-dra7xx.c b/drivers/pci/host/pci-dra7xx.c
index abb85a1..1909899 100644
--- a/drivers/pci/host/pci-dra7xx.c
+++ b/drivers/pci/host/pci-dra7xx.c
@@ -397,7 +397,7 @@ static int __init dra7xx_pcie_probe(struct platform_device *pdev)
 	pm_runtime_enable(dev);
 	ret = pm_runtime_get_sync(dev);
-	if (IS_ERR_VALUE(ret)) {
+	if (ret < 0) {
 		dev_err(dev, "pm_runtime_get_sync failed\n");
 		goto err_get_sync;
BtrLinux
Privacy Overview
