PCI: Delete unnecessary NULL pointer checks
Author: Markus Elfring <elfring@users.sourceforge.net>
The pci_dev_put() function tests whether its argument is NULL and then
returns immediately.  Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Bjorn Helgaas
 drivers/pci/hotplug/cpci_hotplug_core.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/pci/hotplug/cpci_hotplug_core.c b/drivers/pci/hotplug/cpci_hotplug_core.c
index a5a7fd8..46db293 100644
--- a/drivers/pci/hotplug/cpci_hotplug_core.c
+++ b/drivers/pci/hotplug/cpci_hotplug_core.c
@@ -214,8 +214,7 @@ static void release_slot(struct hotplug_slot *hotplug_slot)
 	kfree(slot->hotplug_slot->info);
 	kfree(slot->hotplug_slot);
-	if (slot->dev)
-		pci_dev_put(slot->dev);
+	pci_dev_put(slot->dev);
 	kfree(slot);
BtrLinux
Privacy Overview
