PCI: Adjust confusing if indentation in pcie_get_readrq
Indent the branch of an if.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r disable braces4@
position p1,p2;
statement S1,S2;
if (...) { ... }
if (...) S1@p1 S2@p2
@script:python@
p1 << r.p1;
p2 << r.p2;
if (p1[0].column == p2[0].column):
  cocci.print_main("branch",p1)
  cocci.print_secs("after",p2)
Signed-off-by: Julia Lawall
Signed-off-by: Jesse Barnes
 drivers/pci/pci.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pci/pci.c b/drivers/pci/pci.c
index 7fa3cbd..cc232c0 100644
--- a/drivers/pci/pci.c
+++ b/drivers/pci/pci.c
@@ -2689,7 +2689,7 @@ int pcie_get_readrq(struct pci_dev *dev)
 	ret = pci_read_config_word(dev, cap + PCI_EXP_DEVCTL, &ctl);
 	if (!ret)
-	ret = 128 << ((ctl & PCI_EXP_DEVCTL_READRQ) >> 12);
+		ret = 128 << ((ctl & PCI_EXP_DEVCTL_READRQ) >> 12);
 	return ret;
BtrLinux
Privacy Overview
