[PATCH 2/11] drivers/watchdog: Eliminate a NULL pointer dereference
At the point of the call to dev_err, wm8350 is NULL.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@r exists@
expression E,E1;
identifier f;
statement S1,S2,S3;
if ((E == NULL && ...) || ...)
  ... when != if (...) S1 else S2
      when != E = E1
* E->f
  ... when any
  return ...;
else S3
Signed-off-by: Julia Lawall
Acked-by: Mark Brown
Signed-off-by: Wim Van Sebroeck
 drivers/watchdog/wm8350_wdt.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/watchdog/wm8350_wdt.c b/drivers/watchdog/wm8350_wdt.c
index 89dd7b0..b68d928 100644
--- a/drivers/watchdog/wm8350_wdt.c
+++ b/drivers/watchdog/wm8350_wdt.c
@@ -284,7 +284,7 @@ static int __devinit wm8350_wdt_probe(struct platform_device *pdev)
 	struct wm8350 *wm8350 = platform_get_drvdata(pdev);
 	if (!wm8350) {
-		dev_err(wm8350->dev, "No driver data supplied\n");
+		pr_err("No driver data supplied\n");
 		return -ENODEV;
BtrLinux
Privacy Overview
