OMAP: PM: SmartReflex: Add missing IS_ERR test
Function _sr_lookup, defined in the same file, returns ERR_PTR not NULL in
an error case.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r@
identifier f;
f(...) { ... return ERR_PTR(...); }
identifier r.f, fld;
expression x;
statement S1,S2;
x = f(...)
... when != IS_ERR(x)
if (IS_ERR(x) ||...) S1 else S2
*x->fld
Signed-off-by: Julia Lawall
Signed-off-by: Kevin Hilman
arch/arm/mach-omap2/smartreflex.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-omap2/smartreflex.c b/arch/arm/mach-omap2/smartreflex.c
index 77ecebf..d7deadf 100644
--- a/arch/arm/mach-omap2/smartreflex.c
+++ b/arch/arm/mach-omap2/smartreflex.c
@@ -966,7 +966,7 @@ static int __devexit omap_sr_remove(struct platform_device *pdev)
sr_info = _sr_lookup(pdata->voltdm);
- if (!sr_info) {
+ if (IS_ERR(sr_info)) {
dev_warn(&pdev->dev, "%s: omap_sr struct not found\n",
__func__);
return -EINVAL; |
- if (!sr_info) {
__func__);
return -EINVAL;
