of/overlay: add missing of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
for_each_child_of_node performs an of_node_get on each iteration, so
a break out of the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
expression root,e;
local idexpression child;
 for_each_child_of_node(root, child) {
   ... when != of_node_put(child)
       when != e = child
   return child;
+  of_node_put(child);
?  return ...;
Signed-off-by: Julia Lawall
Signed-off-by: Rob Herring
 drivers/of/overlay.c | 5 ++++-
 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/of/overlay.c b/drivers/of/overlay.c
index 24e025f..54e5af9 100644
--- a/drivers/of/overlay.c
+++ b/drivers/of/overlay.c
@@ -149,6 +149,7 @@ static int of_overlay_apply_one(struct of_overlay *ov,
 			pr_err("%s: Failed to apply single node @%s/%s\n",
 					__func__, target->full_name,
 					child->name);
 			return ret;
@@ -417,8 +418,10 @@ static int overlay_subtree_check(struct device_node *tree,
 		return 1;
 	for_each_child_of_node(tree, child) {
-		if (overlay_subtree_check(child, dn))
+		if (overlay_subtree_check(child, dn)) {
 			return 1;
 	return 0;
BtrLinux
Privacy Overview
